Any diy voltage doublers for a hybrid phev kit?
I've looked around the net quite a bit. I have not been able to find a dc-dc anywhere near what you'd need for a car application. First off, nothing will bump your voltage up to the 144V+ that is needed to charge a car's pack. Second, they don't supply anywhere near the power that the enginer dc-dc converter does.
I'm sure you could contact any company that makes dc-dc converters and they could make you one, but you'd be paying a very high price for it. Its sad to see enginer go out of business. He had a good idea, too bad he just had so many problems with it. The website doesn't say anything about going out of business. Where did you hear this info? DIY is definitely possible, just start reading up about how to build your own dc-dc converter. The concept isn't complex, but it seems controlling everything makes things quite a bit more complicated. I have looked into this a little bit as well. |
what kind of specs do you need?
The easy option that I see is taking a cheap ($300) off the shelf 20amp inverter that has a 48v input, using a step up transformer to get you to the 144v needed or even tweaking it's voltage regulator to give you that 144v output then rectifying it. otherwise I think some of the open source battery chargers that are large switching power supplies take a DC input and can give a wide range of outputs. |
Bridge Rectifiers | Mouser
http://www.mouser.com/search/Product...R=833-MP506-BP These guys are showing 25 amp, 200v bridge rectifiers with a 1.1v drop... at least I think I'm looking at the specs right, either way you would want a heat sink on it as well, maybe a small fan as well. I would look more at the open source chargers and see if the design could be tweaked to work with a 48v DC input. |
-mort |
BTW, Enginer isn't out of business. However, it was sold to a new owner.
