EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Anyone have ideas on how to accomplish this mod: (https://ecomodder.com/forum/showthread.php/anyone-have-ideas-how-accomplish-mod-12733.html)
RandomFact314 03-25-2010 02:46 PM
1 Attachment(s)
Not the top grill block or the head light thing but the bottom of the bumper...
I want to make it flat like in the ghetto-photoshop I did...
I want to do something like this and have some cash to spend but would like to keep it cheap-er... Would just screwing coroplast into the bumper and painting it silver be the best way or is there anyway I can heat up the bumper enough to shape it?
Sounds crazy to heat up the bumper to shape it but W/E :D:rolleyes::thumbup:
Or is this way to much blockage?
http://ecomodder.com/forum/attachmen...1&d=1269542880
Nevyn 03-25-2010 03:07 PM
You might be able to find "kick panel" trim in a close to matching grey at Lowe's or Home Depot. It's like $4 for 3 to 6 feet of flexible rubber that's 4" or 6" tall. I forget the exact name, and can't seem to find it via search.
RandomFact314 03-25-2010 03:12 PM
It would be awesome to block that much of my grill off, I want to start a belly pan too but just up under the front bumper, Just worried about using coroplast cuz that might sag or rip off
Bicycle Bob 03-25-2010 05:19 PM
Two layers of Coroplast can be glued together with beads of Silicon Seal. It takes a while to dry, but gives a very rugged panel. It also makes it easy to make seams and hold curves. There is also a heavy-duty, thicker Coroplast.
cfg83 03-25-2010 05:58 PM
RandomFact314 -
I forgot his name, but there's the dude that did the awesome side mirror deletes and the front foglight covers for his Civic (hatch?).
I don't think that will cost much $, but I it will cost time. Sooooooo, it depends on what you have more of, punk! (as Dirty Harry might say)
CarloSW2
Frank Lee 03-25-2010 06:33 PM
Big Daddy Roth would have used plaster to seal and smooth, then fiberglass over it.
busypaws 03-25-2010 06:57 PM
I still like my shrink wrap plastic. $1.68 at Lowes. It is the stuff you put over your house windows in the winter with double sided tape and then shrink with a hair drier. Since it is clear no need to paint. I put mine on in the begining of winter and still on there. I need to attack it again with a hair dryer since some of wrinkles came back. I've started watching the SG temp guage as the temp warms up. I'm hoping to rig a cooling fan light so I can make sure I'm not overheating.
Devon Hynes 03-25-2010 09:54 PM
I thought about doing something similar. My plans was to buy a second used bumper and stretch fabric over the inlet. fiberglass over it sand, prime and paint.
Devon Hynes 03-25-2010 10:06 PM
http://www.youtube.com/watch?v=kcs1hz8z-9k
Same idea...
arollinstone 03-26-2010 11:24 AM
1.Clear packing tape on the outside. 2.expanding foam in a can. easy if the bumper is removed but if you can get at it from behind it's that much faster. 3.let dry a few days, remove tape and trim off excess foam. 4. Fiberglass coat it.
