April 2009 Modification of the Month nominations
EDIT May 4/09: voting is open, here: http://ecomodder.com/forum/showthrea...onth-8217.html
--- I'll start the ball rolling by nominating skyl4rk's Nissan Versa Base 1.6L This ongoing project started out with some discreet & nicely made grille blocks, and some data collection to document the MPG improvement seen. ... And then WHAM! Out of left field we find a prototype coroplast removable boat tail under construction! http://cruisenews.net/whacked/versa/...4%202009/2.jpg (Hopefully my nomination isn't the kiss of death, skyl4rk - I don't have a bad track record that way.) Anyone else seen any good projects/tests/threads this month? Don't forget, active projects that were previously nominated, but didn't take the crown in previous months are eligible for re-nomination. |
Previous months' contests & winners, FYI:
http://ecomodder.com/forum/showthrea...onth-7778.html http://ecomodder.com/forum/showthrea...onth-7325.html http://ecomodder.com/forum/showthrea...onth-7014.html |
I nominate Captainslug's polycarbonate motor mount.
http://ecomodder.com/forum/showthrea...html#post96935 |
Bumping because there is only a week left to nominate!
- Janvos39's Suzuki Burgman: http://ecomodder.com/forum/showthrea...mods-6959.html
Also, Ben, for answering a question I've been wondering about for a long time:
Does a Honda CRX have attached flow all the way down the rear hatchback? http://ecomodder.com/forum/showthrea...lass-8097.html (Yes, tests qualify for the MOTM contest.) |
I'll nominate Wonderboy's vast array of mods he recently did.
I'm nominating wagonman's kammback he has started on his Celebrity.
http://ecomodder.com/forum/showthrea...deas-6715.html Anyone else get your nominations soon! |
