Article: EPA to Fortify Certification Oversight in Wake of Mileage Controversies
It looks like the automakers are going to have fewer opportunities to make "mistakes" (Hyundai/Kia) or "game" (?) the tests (Ford hybrids) to give their cars better EPA fuel economy ratings than they deserve...
Update -- see also: http://ecomodder.com/forum/showthrea...ims-27224.html |
Its nice to see the EPA addressing these issues and doing something about it. Wonder what those 30 people were doing that they won't be anymore though...
God forbid they just lay out an on road real world test track like NHTSA uses to for calculating tire tread wear and gather an actual sample size with multiple test subjects like real scientists do.
Even mythbusters was able to figure out 2 new identical vehicles don't get identical fuel economy even when driven together on the same road at the same time. |
Nothing wrong with proper lab tests. The open road- as you ought to know- has so many variables it is nearly impossible to test with consistency. I thought the last generation of EPA test protocol was spot-on. Yes there is individual variation between "identical" vehicles; is it large enough to worry about and/or do you think a big enough number of each model should be tested?
The numbers they come up with are completely useless anyway. Fuelly is far more accurate at predicting real world fuel economy.
It is a standardized test.
The EPA testing protocol is to compare the economy of models to each other. We all know it has little to do with what each of us will actually get out in the real world. However, some manufacturers have been extensively gaming the tests to gain more marketing ammunition. Now it has come back to bite them.
Random auditing should be sufficient after the first test.
Real world is simply an unrealistic way to test with any consistency. The current EPA may not be perfect, but it's the best "official" measure available at the moment. |
Also, up to now, EPA has NOT had a standard E85 fuel specified, so they relied upon numbers provided from manufacturers tests. They, now, however, have proposed an E85 standard fuel...but, it's not (yet) been approved. |
Kia gives my wife about $90 a year since they had to eat crow and drop her Sorento's highway rating from 32 to 29. I still think they should give her more to cover the difference in used value since the lower mileage rating is a bargaining chip in buying-selling.
regards Mech |
Accounts vary, but links here https://www.google.com/#bav=on.2,or....ends+are+there claim up to 59 different blends of gasoline sold in the U.S.: http://www.gao.gov/products/GAO-05-421 |
