EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Astro Cargovan Headlight Cover (https://ecomodder.com/forum/showthread.php/astro-cargovan-headlight-cover-31838.html)
Blockhead 04-29-2015 07:23 PM
1 Attachment(s)
Hello Aero modders,
First time posting, but have lurked for quite some time. Just trying to do some cheap mods on my work van.
Was thinking of covering the headlight opening with some clear acrylic (plexiglass) to round out that area, and smooth out the air flow. Will this be an improvement, or is this area just dead anyway?
This isn't my van, just a pic from the net, but I have the same style front end. I do have a lower extension on the front spoiler that is below anything hanging down from the body.
Thanks
mwilliamshs 04-29-2015 08:08 PM
http://ecomodder.com/forum/showthrea...asy-31787.html
Although on a vehicle where very aero composite headlights and more a aero grille are available as OE and should be plentiful and cheap as both aftermarket and used, I'd just swap those in.
http://static.cargurus.com/images/si...pic-25028.jpeg
Could probably get everything you need at a pick-n-pull for the same $ and less time as the fab job
Blockhead 04-29-2015 08:41 PM
I'm a regular at the local Pull-a-part, but just the headlight assembly's would be quite a bit more than 2 pieces of plastic. Then I'd have to mess with the wiring, and I hate electrical. The grills are actually the same, just chromed.
Heating, and bending the plastic is easy, plus I have some. I'm just looking for opinions on whether it would be beneficial is all.
mwilliamshs 04-29-2015 09:11 PM
The headlights, "Headlight-Composite, Regular" are $18.99 each at my local yard, part of a national chain. Lowe's has .080 acrylic in 24" x 18" sheets for $11.97. I'm sure it'd take that much excess to bridge the gaps, have mounting flanges, and accept the compound curves required. If you didn't buy a tool, hardware or glue for the project there's $14.04 in savings. Unlikely. But I get the headlights with all hardware and the bulbs etc at the yard for one money.
Just FYI the 5x7, 4x6, and 7" sealed beams share connectors with H4 and 9003 bulbs so no re-wiring to do.
My local yard is a Pick-n-Pull. I have their points rewards card thing ("toolbox" club, I think it's called) and get emails about their half-price days. That'd make the OE upgrade even cheaper than DIY covers.
No doubt it's an aero benefit. That's why GM did it.
Frank Lee 04-29-2015 10:50 PM
You'll never be able to detect any improvement.
mwilliamshs 04-29-2015 10:56 PM
^atypical positivity^
Surely a good sign
Frank Lee 04-29-2015 11:02 PM
Truth.
deejaaa 04-30-2015 12:30 AM
it's been proven that the real benefit is at the rear.
mwilliamshs 04-30-2015 01:16 AM
Well...
The greatest opportunity for improvement is at the rear but that doesn't mean front-end work is a waste of time or that benefit there is fake as opposed to "real". :)
70+ sqare inches of awful up front is worth improving IMO (5x7 headlight = 35 sq in x 2 = 70 plus all the gaps and edges nearby). Every bit of air you help get over/around the front is that much more opportunity for improvement in the rear.
Sven7 04-30-2015 02:11 PM
Yeah, you can improve the front, but unless you're bored there's no real reason to mess with the headlights. Work out your grille block and air dam first, cover the rear wheels, put wheel covers on the fronts and then start on a kammback. Since it has barn doors on the rear, mounting shouldn't be a huge issue.
You're going to see the greatest gains at the back, but from experience, it is the most difficult mod to do. Check out this for ideas...
Blockhead 04-30-2015 07:09 PM
So, the grill block would be more effective than smoothing the headlights?
I thought about wheel covers, but these are 16" rims. ID of the rim is about 17" Any good threads on covers this big?
mwilliamshs 05-01-2015 12:11 AM
17" Aluminum Coupe Pizza Tray $4.03 each
http://www.amazon.com/New-Star-50776...0453386&sr=1-3 $10.80 each
http://www.amazon.com/Update-Interna...0453434&sr=1-6 $4.51 each
http://www.amazon.com/Johnson-Rose-C...453534&sr=1-12
like the end of Happy Birthday..."and mannnnny mooooooore"
Blockhead 05-01-2015 06:18 AM
Thank You.
Sven7 05-01-2015 10:54 AM
Yes, the air going into the grille tumbles around the engine bay and causes all kinds of ruckus; the same is true of air going underneath the van, hence the air dam suggestion. Headlight covers, you might say, are the high-hanging fruit.
We have lots of threads on grille blocks and air dams for large vehicles, so search around and you'll have plenty of reference material!
deejaaa 05-01-2015 11:19 PM
Originally Posted by mwilliamshs (Post 477544)
$4.03 each, 24/lot, $96.72 + shipping.
mwilliamshs 05-02-2015 01:59 AM
yeah that's a restaurant supply company, not likely they see many orders for only 4 trays LOL webstaurantstore was just my first idea to check. Amazon had more to choose from
All the amazon examples should be more conducive to ecomodding. For the record I've done business with that company and they're good people.
If you're serious about pizza trays as wheel covers it'd be worthwhile to speak with the owner/manager of a local pizza joint (mom & pop place especially) and see about buying old trays or chipping-in on their next order. Lots of people used to buy used oyster trays from my bar. Enough that we started selling new ones outright and I got our logo put on them just for that purpose.
aerohead 05-02-2015 01:33 PM
beneficial
I ran across a mid-80s CAR and DRIVER and they mentioned that an Audi of the day,with flush headlamps DID show a drag improvement over the bucket.
The ASTRO has vary ample edge radii at the top and sides where the flow would be bleeding off to,and I agree with Frank that you might not see a 'showing' at the gas pump.
You're at Cd 0.38.The Pontiac Trans Sport was around Cd 0.30.The 1991 GM HX3 was Cd 0.258 I think.I'd want to study the differences
