04-29-2015, 07:23 PM
Astro Cargovan Headlight Cover
Hello Aero modders,
First time posting, but have lurked for quite some time. Just trying to do some cheap mods on my work van.
Was thinking of covering the headlight opening with some clear acrylic (plexiglass) to round out that area, and smooth out the air flow. Will this be an improvement, or is this area just dead anyway?
This isn't my van, just a pic from the net, but I have the same style front end. I do have a lower extension on the front spoiler that is below anything hanging down from the body.
Thanks
The Following User Says Thank You to Blockhead For This Useful Post:
04-29-2015, 08:08 PM
http://ecomodder.com/forum/showthrea...asy-31787.html
Although on a vehicle where very aero composite headlights and more a aero grille are available as OE and should be plentiful and cheap as both aftermarket and used, I'd just swap those in.
http://static.cargurus.com/images/si...pic-25028.jpeg
Could probably get everything you need at a pick-n-pull for the same $ and less time as the fab job
The Following User Says Thank You to mwilliamshs For This Useful Post:
04-29-2015, 08:41 PM
I'm a regular at the local Pull-a-part, but just the headlight assembly's would be quite a bit more than 2 pieces of plastic. Then I'd have to mess with the wiring, and I hate electrical. The grills are actually the same, just chromed.
Heating, and bending the plastic is easy, plus I have some. I'm just looking for opinions on whether it would be beneficial is all.
04-29-2015, 09:11 PM
The headlights, "Headlight-Composite, Regular" are $18.99 each at my local yard, part of a national chain. Lowe's has .080 acrylic in 24" x 18" sheets for $11.97. I'm sure it'd take that much excess to bridge the gaps, have mounting flanges, and accept the compound curves required. If you didn't buy a tool, hardware or glue for the project there's $14.04 in savings. Unlikely. But I get the headlights with all hardware and the bulbs etc at the yard for one money.
Just FYI the 5x7, 4x6, and 7" sealed beams share connectors with H4 and 9003 bulbs so no re-wiring to do.
My local yard is a Pick-n-Pull. I have their points rewards card thing ("toolbox" club, I think it's called) and get emails about their half-price days. That'd make the OE upgrade even cheaper than DIY covers.
No doubt it's an aero benefit. That's why GM did it.
04-29-2015, 10:50 PM
You'll never be able to detect any improvement.
04-29-2015, 10:56 PM
^atypical positivity^
Surely a good sign
04-29-2015, 11:02 PM
Truth.
04-30-2015, 12:30 AM
Not banned yet
Blue - '03 Chevy S-10, LS
it's been proven that the real benefit is at the rear.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
04-30-2015, 01:16 AM
#9 (permalink)
Well...
The greatest opportunity for improvement is at the rear but that doesn't mean front-end work is a waste of time or that benefit there is fake as opposed to "real".
70+ sqare inches of awful up front is worth improving IMO (5x7 headlight = 35 sq in x 2 = 70 plus all the gaps and edges nearby). Every bit of air you help get over/around the front is that much more opportunity for improvement in the rear.
04-30-2015, 02:11 PM
#10 (permalink)
Yeah, you can improve the front, but unless you're bored there's no real reason to mess with the headlights. Work out your grille block and air dam first, cover the rear wheels, put wheel covers on the fronts and then start on a kammback. Since it has barn doors on the rear, mounting shouldn't be a huge issue.
You're going to see the greatest gains at the back, but from experience, it is the most difficult mod to do. Check out this for ideas...
