EcoModder.com
-   -   Auto in N question (https://ecomodder.com/forum/showthread.php/auto-n-question-4371.html)
Doofus McFancypants 08-05-2008 11:37 AM
Auto in N question
The family and I went to see my Brother in NC this past weekend
We took the PT Crusier - auto tranny.
I did hook up the SG so i could see how we did.
I gathered data on the car at several speeds to get a feel for the impact MPH on MPG
While doing this - i also wanted to see if coasting in gear was better or worse then costing in Neutral.
From a consumptiuon point of view - coasting in N seemed to use slightly LESS fuel than coasting in gear. I suspect the PT does not have a fuel shut off as the MPG did not skyrocket.
Both cases had the instant MPG jump to about 75 ( N hit 80 a few times) hence i called it SLIGHTLY less fuel.
I wanna play with it some more and get more data - a little more contolled than "30 minutes of data crusing across SC)
Here is my observation and question.
When i shift the tranny into N - I expected the RPM to drop to Idle - which is what the Manual in my Altima does... but it did not?
going 65 mph was about 2400 rpm or so. shift to N - engine stayed near 2400 RPM ! HUH? Both the TACH and the SG said this..
the MPG did go up so i know less fuel is going IN -
Is this normal for an AUTO? Am i thinking "Manual Tranny" here?
I do not drive the Crusier much ( wifes car) so i had not played with it before. but am a little confused at this.
Steve
azraelswrd 08-05-2008 11:49 AM
Wow, that is interesting. I can only speak from my own experiences with the Scion XA (automatic) and when I go to N from 45 (since that's where I usually drive at) my RPMs take a dive from 1800-1900 down to 700-900. MPG gains are immediate (instant and current trip) but I'm trying to get into the habit of DFCO coast first then N-coast once I'm below the minimum 1200-1400 rpm to make the most out of fuel consumption.
BrianAbington 08-06-2008 10:49 AM
it may be an idle controler problem
bryn 08-06-2008 11:30 AM
mine drops to idle also.
what happens if you rev the engine a little? it might not be totaly out of gear.
BBsGarage 08-06-2008 01:44 PM
What is the idle after it has warmed up?
95badbird 08-06-2008 01:50 PM
My wifes 02 Taurus does that as well....it seems as if speed and RPMs are in direct corelation with each other.
The more I slow down, the RPMS drop......
FastPlastic 08-06-2008 02:52 PM
My Jeep Cherokee works the same way. Makes the N coasting basically worthless on the Jeep. especially since it has the fuel cut off. The only difference I see is I can coast just a little bit farther. The only time I use N is when I'm sitting at a light. Drops the fuel use from 0.74gph to 0.60gph.
wagonman76 08-06-2008 10:52 PM
Within a couple seconds mine drops to 800-1000 rpm when going to N at any speed. Dont have my mpguino done yet but Im sure Im using less fuel in N as well.
Doofus McFancypants 08-07-2008 12:25 PM
Next time i am in it i will check a few things.
warmed up idle ( Stoped in D)
warmed up idle ( Stoped in N)
Coasting in gear ( at some MPH)
Coasting in N ( at same MPH)
i will check the GPH and the RPM at those cases.
with that info I will hit the Crusier forums and see if this is common or an error
thanks for the inputs
steve
nascarnation 08-07-2008 09:09 PM
A lot of this depends on the gear and control layout of the transmission.
Because there potentiall could be a big difference between the engine speed (low)and the trans output speed (high), and what gear range is selected from neutral to re-engagement.
Some control strategies will hold the engine above idle in a neutral coast to reduce trans load on re-engagement.
