Old 11-04-2009, 03:22 PM   #1 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
How to Flush Gearboxes and Bearing Housings
Gearboxes and bearing housings periodically need a thorough flushing rather than a simple drain and fill. Several signs point to this requirement, such as overheating of the sump, gross liquid or solid contamination, and development of a severe wear pattern. Material evidence in the form of sludge, rust, moisture, wear metals, gel or other viscous residue that is present at the beginning of the drain should confirm to the technician that a flush is in order. A thorough flush is also useful for removing construction and assembly contaminants from equipment sumps prior to commissioning.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 11-04-2009, 07:17 PM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
If you pay due diligence to your maintenance, that is unneeded, because the problems never show up in the first place.
www.HyperKilometreur.com - Quand chaque goutte compte...
