Automotive Aerodynamics (video series)
Hey guys,
I recently started a video series on automotive aerodynamics. During my research for each episode, I am often directed to this forum. So I thought I'd share my findings, enjoy! www.youtube.com/watch?v=quDLzxmJl5I https://www.youtube.com/watch?v=IFDZCIYe3RY https://www.youtube.com/watch?v=LNnrY65-u-k https://www.youtube.com/watch?v=AwD-UCd22Vw |
Welcome !
Great to have you here. |
Thank you, I look forward to any input and constructive criticism (suggestions) for future episodes
Wow!
Quite a contrast between the garage (the one with the oriental rug on the floor. Can you get your car in there?) and the water tunnel (how many horsepower does that consume?) How do you get access to the water tunnel? Will you graduate and have it go away or do you have a permanent job there. Did you see Yoshi Suzuka's work before it disappeared from Youtube? I notice in Automotive Aerodynamics Future Episode Preview! you are soliciting models for testing. I built this in 1995, but I'd let you thrash on it: http://ecomodder.com/forum/member-fr...re5624-vw1.jpg Anyways, I guess I know where the next few hours are going, even though it's sunny outside. :thumbup: |
Can you measure forces in the water tunnel? If so, do you see expected increases / decreases in drag, when adding spoilers onto models?
Great idea for a video series!
My initial suggestion, in this era of shortened attention spans, is on episode length. I'm only partway through one (surprise: I chose the shortest one to view first... then again, that's because I should be working :) ) and it's fantastically info dense! If your goal is a seminar-type program (and I suspect it is), that's fantastic. But if your goal is widest viewership, it may be a drawback. But now I know what I'll be doing for another couple of hours in the near future. Obvious suggestion (if it hasn't been made yet): examination of some DIY drag-reduction mods, as found throughout our aero subforum. Also: welcome to the forum! Darin |
Awesome! Only watched the first video so far but looking forward to the rest!
Briefly sampled a few more. Just fantastic - this thread is going on the front page.
(FYI, future replies to this thread bump it to the top of the list.) |
I'm in between classes right now so I only watched the first 5 minutes of the first video but the series looks awesome!
Is it possible to add miniature tufts to the car models for tuft testing, or is water too dense to show this accurately ?
( I'm currently halfway through the first video, so i may have missed any tuft testing if you did it later in the series. ) |
video series
Welcome!
All smiles here!:) The idea and the work is great.These images speak volumes.I can't think of a better way to share. If I could get it into public school curriculum I would.Consumers would have a very concrete conception of what was happening around their vehicle as they drove.The higher Reynolds number stuff really tells the tale.(tail?) Can't thank you enough,and look forward to future releases.:thumbup: |
HAHAHAHAHA me and my girl have a at home movie night where we both take turns picking a movie to watch for a "free" at home date night she is going to get a shock from this!!
This is why we take turns! lol
I found this 1/10 scale Civic hatchback.
1/10 scale is too large to fit in the tunnel, correct ? http://www.rctech.net/forum/attachme...int-rc-061.jpg |
Here's another one he did with the solar car in a wind tunnel. https://www.youtube.com/watch?v=BHeVEKCObKU > |
I would definitely love to see how some of the more popular cars that are generally used for hyper milling stack up aerodynamically in wind tunnel testing. Very awesome videos!
Thank you,
For all those of us without aerospace degrees and without access to wind tunnels and water channels this gives us the chance to vicariously be there and learn from your experience. Thank you greatly. Subscribed so as to get any future updates, benphyr. p.s. I am down the road in Hamilton. Are you interested in visitors to your "shows" or testing or garage from ecomodders in the neighbourhood? |
I enjoyed watching and suggest the following:
1. Reduce the length of each video by 25%. Spend less time on the intro and the exit from each idea, and instead just present the idea. In the first video, too much time was spent revisiting which cars are being tested, and which books were used to gleam the info. That sort of material can be added in the notes to the video instead of occupying the valuable meat of the info. 2. Develop an elementary intro to aerodynamics that discusses things like why attached flow is desirable, and how various high and low pressures develop and what those forces do to the vehicle. 3. Break the ideas up into smaller segments. This will help to reduce the intro video length. An independent video can explain how hydrogen bubbles are produced for those that are curious, but hydrogen bubbles don't have anything directly to do with aerodynamics. I think the mistake most (uniformed) people make when conceptualizing aerodynamic shape is that they think in terms of cutting through the air. People already know through experience that a sharp blade cuts through objects better than a blunt object, and so their focus is drawn to separating the air at the front of an object while neglecting the other aspect of bringing the fluid back together again. This focused attention at the leading edge is likely why roof racks appear to the public to be designed with aerodynamics in mind, while the trailing transition is neglected. I'm curious if very small aerodynamic changes can be observed and/or measured at small scale using your equipment. On Ecomodder, people add moon discs or wheel spats, and it would be neat to visualize the change that makes, or have data to quantify the drag reduction (or even increase). |
I'm also interested in a segment that covers belly pans. It's kind of cool being able to see the slowed down flow of bubbles underneath the car when you show the pulses of bubbles.
I would be interested in seeing flow alongside of the vehicle after seeing the addition of wheel farings, and the vertical spoilers on bumpers and pillars.
Great stuff, graysgarage! I have a Bachelor of Aerospace Engineering and have experience in wind tunnels and water channels (actually, water tables, but the same principle, of course) and appreciate you making these videos easy to understand for non-engineering types.
Flow visualization for minivan
These are great videos. Would love to see the flow studies for a minivan (ie Town & Country).
wowzers! Thanks so much for donating this valuable info to us! I am busy streamlining a camper trailer design, and working on some aero mods of wifey's mini-van. Your illustrations sure help reenforce my intuitions and previous research. Thank you!
Thanks for these videos, they really help.
I'd be interested in seeing the car rotated some. Most of the time, due to wind, the air does not flow straight from front to back, but crosses at some angle, if I am not mistaken. I'd also like to see some commentary about the size and length of the rear wake, and how that affects the drag. I got the impression that sometimes a rear spoiler increases the drag, and sometimes it decreases it, and wondered why. |
New video up ! Nice and to the point, and very informative.
https://www.youtube.com/watch?v=byA_tp0DINc Thanks for posting ! |
https://www.youtube.com/watch?v=5UdROEOUyvg
New video posted of a 6th generation Civic. The videos are now concise, and too the point. ( Bravo ! ) Another thing I was glad to see was a side by side comparison of the tests. ( at the end of the video ) Overall, a much more professional quality to the video. I found it really interesting that the mid spoiler was functional on the 6th generation Civic. I wonder how much of an effect it had with a 5th generation model though, since the angles of the rear glass are quite different. Thanks to this video, I can see why that a 6th generation car would have a higher drag than a 5th generation. Thanks for posting ! |
In the first video you wanted to correct misinformation about aerodynamics.
I haven't noticed anything that points out any misinformation that you've corrected. Could you make a video specifically for this purpose? |
Hey everyone,
Thank you for the feedback. I'm new to making videos and am still learning how to best shoot, edit, and present the information. If anyone has models they would like to send me, anything in the 1:18-1:10 scale please send me an email. Also, if anyone has questions or specific requests, please email me. You can find all my info on my website graysgarage.ca I don't check forums very often, so this is the best way to reach me. Thank you for the support! New video btw https://www.youtube.com/watch?v=vzMe1e9fE50 |
amazing very nice idea. aerodynamic miniature :thumbup:
Cda test request for a 91 Dodge"brick" Ram
Helow
[QUOTE=graysgarage;474540]Hey everyone, Thank you for the feedback. I'm new to making videos and am still learning how to best shoot, edit, and present the information. If anyone has models they would like to send me, anything in the 1:18-1:10 scale please send me an email. I just purchased the only model for a 73-93 Dodge PU 1:43 scale. You said larger 1:18 to 1:10 is preferred, However, in the old stack of bricks design Dodge 1;43 is all i could find. The new trucks are every where in the proper scale http://rover.ebay.com/rover/0/e11070...xe=exe,ext=ext Also, if anyone has questions or specific requests, please email me have you added the link for this.?. You can find all my info on my website graysgarage.ca good info hear thank you I don't check forums very often, so this is the best way to reach me. you tube didn't get a response Eather Thank you for the support! My hope is that i can buld an accurate 1;43 removable canipè. To sind with the truck. For TESTING will pm you for an address to sind to |
1/24th is headed the wrong way. 1/3rd to 1/5th is best-er.
OP most recent post is still the solicitation at Permalink #29. Perhaps aerohead could suggest whether a fluid with less viscosity like rubbing alcohol or more viscosity like melted coconut oil would be better at 1/43rd scale. |
Was hopeful that my body type and year range could have its Cd info populated the newer dodge is available in 1:10 '73-'93 body I have only ben able to find in 1:43.
In one ofvhis videos he was able to 3D print a model that was not available. Can anyone find the stock. Cd. CdA ect. Ect. For a '91 dodge D250. Sorhat I can so my % gain on Cd from down hill cost down testing mpgs show 27% FE improvement =54% improvement in drag reduction What do you guys/gals think?? |
Ha me too freebeard i was making a funny face trying to decifer it.
54% geez thats a big drop in drag. My cap is a similar shape, i was guessing 1/4 to 1/3 reduction in drag, but would be happy to be wrong! |
viscosity
Texas Tech used as small as 1/24-scale in their water tunnel. At very small scale we risk cavitation as low local pressures force a phase change in the working fluid. |
CdA
The D-100 1/2-tons were around 31.5 sq-ft frontal area. I'd estimate the Cd at around 0.525. |
27% fe
These relationships are predicated upon steady-state highway cruise mpg,not coasting or coastdowns. Also,we have no idea what the engines BSFC is doing with the modifications,and all the relationships presume a constant BSFC,or gear-matching to achieve a constant BSFC which may not reflect reality. |
reduction
Questions
Sorhat (so that)I can so my(find my) % gain on Cd from down hill cost down testing(turmnal velocity testing instead of) mpgs... (improvement for drag improvement value)
This part makes my head hurt. Sorry temporary tourettes |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
