EcoModder.com
-   -   AutoSpeed - DC to DC converter solution for alt-less modders (https://ecomodder.com/forum/showthread.php/autospeed-dc-dc-converter-solution-alt-less-modders-9461.html)
Daox 07-30-2009 10:16 AM
Autospeed may have come up with a solution for our DC to DC converter problems. They used a laptop voltage converter rated at 80W (and tell how to increase that) to power a few simple things. Enough for the ignition and fuel pump? Perhaps, but at the price, you could probably just use two.
AutoSpeed - Voltage Booster
Here is an example I found on ebay.
http://cgi.ebay.com/UNIVERSAL-DC-CAR...d=p3286.c0.m14
SVOboy 07-30-2009 10:19 AM
I feel like they wrote that just for us :p
tasdrouille 07-30-2009 10:45 AM
Funny thing is I read that earlier this week but never thought about the use it could have to ppl going altless. Thx for sharing.
orange4boy 07-31-2009 02:42 AM
dc-dc converter 276 watts.
Finally.
I have tried to find one of these for ages. I knew they existed but i couldn't find any with enough capacity for the ignition and fuel pump.
DC/DC Converter, retail, wholesale, off-the-shelf and custom, 5 watts to 800 watts
$150 is a little steep but at least we know they exist.
I swear there are also dc-dc converters/chargers too so you only need one piece of equipment but I have not found them again.
NiHaoMike 07-31-2009 11:39 AM
It actually isn't very difficult to build one. I asked a friend about it and she has an idea of how it can be designed. No schematic but the idea is in the following link: diyAudio Forums - 11.5-12.8v to 13.8-14.4v boost - Page 1
Christ 07-31-2009 01:52 PM
MPaulHolmes - ready to start a new electronics project? LOL
gascort 08-04-2009 09:13 AM
I wonder how much the one from Daox's article can handle once you mod it? 10A?
I'd be interested in learning how to build one; I'm already having a friend who's good with electronics help me make a charge controller for my solar panels.
Daox 08-04-2009 09:53 AM
I also wonder if its possible to just replace that chip with one that is rated for more power...
gascort 08-04-2009 01:59 PM
Looking back at MetroMPG's page on alternatorless living, Plug-in Blackfly: going alternator optional nets +10% mpg - MetroMPG.com
I saw that the car cited, a 94 civic, needed about 165W to run the engine and fuel pump only.
Maybe 3 of these in parallel, with beefed-up connectors?
Still looking at NiHAO Mike's suggestion...
gascort 08-04-2009 02:12 PM
Oh, one more thing, my homemade solar panel project is underway, making (first) a 54W panel and then expanding it to 108W for a total cost of $175. If the numbers are correct, if I double my plans, I could drive indefinitely without the alternator as long as the sun was bright and I have gas in the tank!
