AutoSpeed: lightweight, simple composite construction technique (monocoque + body)
Julian at AutoSpeed has started what looks like another really interesting series:
Building an Ultra Light-Weight Car, Part 1 An incredible way of producing your own vehicle If you follow the green car blogs, you probably saw the University of South Australia's tandem tadpole trike EV in 2008: http://us1.webpublications.com.au/st...110989_8lo.jpg Part 1 of this series shows how the students laid out that design and made its monocoque tub out of honeycomb sandwich fiberglass panels: http://us1.webpublications.com.au/st...10989_25lo.jpg Quote:
I've seen a lot of new research places build carbon fiber cars that weigh less than 2000lbs. The auto manufacturers refuse to do that. At least BMW started putting in CF roofs, got to start somewhere.
Very interesting article indeed!
Compaq, it's all about the money. I bet material and manufacturing costs for CF are prohibitive compared to pressed steel panels. |
CF problems
The expense of CF is one thing, but the safety is another. Carbon fiber in the passenger compartment can become lethal in a crash. During a crash it turns into sharp strong shards capable of ripping a person apart.:eek:
That being said, I like the idea of CF for fenders, hoods, trunk lids, and the entire trunk if it's not a part of the passenger compartment. |
I used to work in the health and safety area of the advanced composite industry and here are my thought as to why composites are not used much in cars.
Balsa or plywood framing? Hemp fibre and corn resins for panels? Alloy subframe with polystyrene hand carved shell?
Some design principles could be sooo easy like pressing an alloy sheet into a big 1 piece skirt that is essentially the whole body shell, on top a little jetsons clear bubble, hinged on one side that flips open to get in and out off. 2 piece's period! over an alloy subframe with a ply and carpet lined cockpit, that seals against the bubble. |
Hello -
In terms of the CF price issues. the Rocky Mountain Institute Hypercar venture spinned off into this : Fiberforge: Lightweighting Your World With Thermoplastic Advanced Composite Parts Quote:
Fiberforge: Resource Library, Thermoplastic Advanced Composite Technology Question: I heard that CF was *not* recyclable in the way that steel and other metals are. Is this true? CarloSW2 |
I wondered that as well... then i found out that this laptop that i'm typing on is made of a plastic containing shredded recycled carbon fiber - as are most laptops. Strong, light, cheap.
