Old 10-01-2010, 02:55 PM   #1 (permalink)
Side Air Spoilers on SUV?
My 2002 4WD V6 Toyota Highlander gets 20-21 mpg, and I have plans that I hope will boost the mpg to 25. At present it has NO roof spoiler. I previously owned a '84 Tercel, and I added an aftermark aluminum spoiler wherein its cant could be adjusted; moreover, the underside of the spoiler was curved. We all know that the airflow at the back of SUVs is a mess and hurts the mpg. What if I had 3 spoilers: one on the roof, and one on each side (near the rear), with adjustable cants? I know it is do-able, but will it result in increased mpg?
Old 10-01-2010, 08:09 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Your biggest gains will most likely come from simply changing your driving style ( less idling etc. )
Adding small spoilers to the rear of the vehicle will help a small amount, but only if they keep the airflow attached instead of tripping it into a larger wake.
To see a real improvement, you would need a large Kammback, like the one MetroMpg tested on a full-size van.
Old 10-01-2010, 08:22 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I'm not finding the thread that was done on that van that I mentioned.
Sorry
Old 10-01-2010, 09:44 PM   #4 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete)
This is the one you are thinking of Cd.
The Following User Says Thank You to wyatt For This Useful Post:
Cd (10-01-2010)
Old 10-02-2010, 10:08 AM   #5 (permalink)
I have had a ScanGuageII on my SUV for years and have perfected hypermileage driving. You wrongly assumed that I don't know how to drive for good gas mileage.
Old 10-02-2010, 10:57 AM   #6 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Hi Buddy,
My driving change occurred in the spring of 2007 when the gas price first hit $3.50 a gallon.
I started driving slower on the backroads, on the way to work. My first increase was on a Cavalier, where the mileage went from 35 mpg or so to a typical 42 mpg, for a gain of roughly 20% .
Next I did the same thing on my motorcycle and saw it's mileage go from 58 mpg to a typical 73 mpg, for a gain of roughly 20%. I get another 2 or 3 mpg by shutting the motor down and coasting when coming to a stop sign. Just before stopping, I pop the clutch and start the motor back up. I can usually do this since I'm running on the backroads, rather than the main highway.
I think Cd was trying to elaborate on this process and may have given a few more details to try and help.
I would certainly try the spoiler/Kammback edging on your vehicle and see how that helps. Even if you get another 2 or 3% gain, it's still worth it when considering just how important our natural resources are.
Jim.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Adding air to side mirrors. Peter7307 Aerodynamics 25 09-04-2010 01:22 AM
Air Cleaner mod? binarycortex Success Stories 7 05-13-2009 12:44 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
