EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Average speeds (https://ecomodder.com/forum/showthread.php/average-speeds-8303.html)
The Atomic Ass 05-09-2009 09:37 PM
Average speeds
So what is everyone's average speeds on their daily drives? It takes me between 35 and 40 minutes depending on traffic, to travel 13 miles, for an average barely at 20mph. :mad:
This would not be a bad thing if I could maintain 20mph the whole way there... ;)
SVOboy 05-09-2009 09:44 PM
Edit: Nevermind
Lazarus 05-09-2009 10:36 PM
On my SG I it would show my tank average between 30-35 mph.
cfg83 05-10-2009 01:39 AM
The Atomic Ass -
This is my "milk run", from home to work :
ROUTE : 10 West -> 710 South -> 105 West -> 405 South -> Exit Freeway => Roughly 27+ miles
NET ELEVATION CHANGE : ~210 feet drop
SCANGAUGE "CURRENT" READINGS :
60+ MPG,
0.5 to 0.4 Gallons,
27+ Miles,
2100+ RPM Max,
0.5 to 0.6 Hours,
55+ MPH Max,
47 MPH AVG
If the traffic is goldilox, I can lower my average speed and (usually) increase my MPG. It's ironic because I *need* congestion to maintain a lower average MPH, but the increased congestion puts me at risk of hitting a traffic jam. It's a balance.
CarloSW2
The Atomic Ass 05-10-2009 09:09 PM
Originally Posted by SVOboy (Post 103262)
Edit: Nevermind
Too late, I saw your smart-Assery. :D
almightybmw 05-11-2009 01:20 AM
3.3 miles, 7 minutes via car, 11 minutes for biking. Those are maximums aiming for fuel (me and the car) conservation. I can bike it in 8 minutes and drive it in 5 minutes. But it's not worth the burn.
Summary: My average sucks too. No highways, never above 40mph.
wagonman76 05-11-2009 12:24 PM
Going to work or home takes about 40 minutes, and it is 25.6 miles, so 38.4 mph average. Several stops and turns and steep hills, plus a lot of the roads are junk.
The Atomic Ass 05-11-2009 08:37 PM
How high your average is isn't really important, it's how it compares to your maximum speed during the trip. If you're covering 3.3 miles in 7 minutes, that's an average speed of just under 29mph. Which is good compared to a top of 40. Higher averages vs. top speeds almost always means better FE.
By contrast, my peak speeds will reach as much as 55mph on some hills, and is closer to 40mph on flat ground, yet my average speed is barely 20mph. :(
So really, you\'re doing better than me, despite the shorter drive, and generally colder cycles.
almightybmw 05-12-2009 02:52 AM
well when you put it that way I\'m sure doing great. But I love driving fast, so I think I\'m doing bad. :P
vtec-e 05-12-2009 04:01 AM
37 mph. Which is weird because most of my commute is at 50 mph but i guess the slow bits at each end affect things more than i\'d guess.
ollie
