EcoModder.com
-   -   AWD! 2011 Suzuki SX4 6 speed manual build thread (https://ecomodder.com/forum/showthread.php/awd-2011-suzuki-sx4-6-speed-manual-build-35038.html)
Hypermiler1995 04-04-2017 09:39 PM
1 Attachment(s)
Needed an AWD car with decent ground clearance, wanted decent fuel economy and manual, got this; 6 speed manual, 2.0 vvt i4, about 2850lbs, and an AWD system that can be switched to fwd only via a switch in the center console. Has an instantaneous​ and average mpg readout on the dash, cool stuff! Ordered racing disks already :D didn't try hard to get mpg on the drive home even had the ac on and mid 30's on the indicator! Goal is 40mpg 90 day average, shouldn't be hard!
http://ecomodder.com/forum/attachmen...9&d=1491356348
Pryme 04-04-2017 11:28 PM
I always thought those Suzukis were cool.
roosterk0031 04-05-2017 05:02 PM
I like them too, was one my last choices when I got my Cobalt, decided I'd just stay home if FWD won't get me to work and take the better MPG. I'll be curious to see how well you can do.
cRiPpLe_rOoStEr 04-05-2017 07:45 PM
I don't remember to have ever seen the 4WD one with a manual transmission.
Hypermiler1995 04-06-2017 12:56 PM
All years had the option of a manual, 2007-09 was 5 speed, 2010 on was 6 speed, it runs about 2000rpms at 50mph. In other news I'm finding out eoc is easier than I thought, very seamless bump starts! :thumbup:
Hypermiler1995 04-06-2017 04:46 PM
1 Attachment(s)
Not really a noticable weight savings or aero benefit, but I removed the side impact strips, looks a lot better! I get my racing disks tomorrow!
http://ecomodder.com/forum/attachmen...2&d=1491511475
Hypermiler1995 04-07-2017 12:38 PM
1 Attachment(s)
This car now looks like it belongs on this site!:thumbup:
http://ecomodder.com/forum/attachmen...6&d=1491583073
Fat Charlie 04-07-2017 12:48 PM
Love the little Suzukis. I had a 96 Esteem sedan that sometimes got below 40 mpg, driving it like I stole it. A wagon, and AWD when you want it? That's awesome!
cRiPpLe_rOoStEr 04-07-2017 11:09 PM
It actually doesn't look so bad with those moon caps. What have you used to keep them in place?
Hypermiler1995 04-07-2017 11:22 PM
I kinda cheated, they are actual racing disks, so they fit on like regular hubcaps
Hypermiler1995 04-08-2017 05:15 PM
Trying to figure out what material to use for a kamm setup, I want a clean design so no coroplast, it's gonna be a "factory style" setup if that makes sense, so not huge, need to use something that can hold up and won't sag or need bracing, wanting a kind of plastic, found something called expanded plastic PVC that sounds good, thoughts?
Hypermiler1995 04-09-2017 05:52 PM
1 Attachment(s)
Ordered some 3M tape and a 24"x28"x1/4" sheet of expanded pvc, smooth finish, easy to use, and only $25 a sheet:thumbup: Will be building a multipiece stealth kamm, consisting of a 3 piece top "spoiler" and multiple side pieces so the shape flows well with the car, all will be painted to match! Might do a YURASTYLE design over the taillights.
http://ecomodder.com/forum/attachmen...7&d=1491774717
Hypermiler1995 04-18-2017 05:55 PM
UPS returned plastic to sender as it was damaged:( they're sending a new one, so studying the front, have 3m tape and some thin aluminum, going to smooth over the area where the fog lights are supposed to be, at the same time I'm trying to part out my Subaru on eBay, fun:o
Hypermiler1995 04-21-2017 03:55 PM
3 Attachment(s)
Got the plastic, made a cardboard template, and cut out the plastic, now I just need to sand and paint
http://ecomodder.com/forum/attachmen...4&d=1492804475
http://ecomodder.com/forum/attachmen...5&d=1492804475
http://ecomodder.com/forum/attachmen...6&d=1492804475
Hypermiler1995 04-23-2017 12:06 AM
2 Attachment(s)
Results:
