EcoModder.com
-   -   AX 1,4 Diesel 100 mpg Project (https://ecomodder.com/forum/showthread.php/ax-1-4-diesel-100-mpg-project-26108.html)
Rubberduck 06-09-2013 11:35 AM
Hello Ecomodders
I have found this Forum , looking the Themes of Hypermiler AX , i have seen on Spritmonitor . his works at the ax was very inspiring and helpfull for me .
now my own thread about my Citroen AX 100MPG Ecoproject .
I Know that is not easy to realize , but it´s not Impossible . I have so many ideas , dont know if its all good but we will see .
the actually consumption for the last 1400 Km was 3,53 Liter per 100 Km .
The Car is my mileeating rolling Project . so at first the smaller modifications .
for Parts i have 2 other ax1,4 Diesel :
http://2.bp.blogspot.com/-WhKqxb-Ma9...iletraeger.jpg
The first Modifications were , a lighter Right Foot of the Driver , removing Antenna :
http://3.bp.blogspot.com/-x81KbAvQCL...nnaremoved.jpg
Roof Spoiler from the GT Model :
http://4.bp.blogspot.com/-4l6rGZVUY4...achspoiler.jpg
Mirrors from a yamaha fzr1000 :
http://3.bp.blogspot.com/-Rcgqous8m9...enspiegel1.jpg
one of the next modifications will be the lowering springs and Gasshocks :http://2.bp.blogspot.com/-UJ7IbQ-1Ka...0/fahrwerk.jpg
also i am searching for Cheap 145/80-13 Michelins from Opel Corsa , they are 1,3% bigger in Diameter than the original 155/70-13 .
The 5th Gear ratio like Hypermiler AX has , i have ordered , hope that i can install it soon .
and when my ordered PWM comes , i will take a hho cell for testing the consumption . friends of me have reductions of consumption by tdi´s up to 25%
that are the Mods in the nearer Time .
Later will follow Ligtweighting of the Car and some greater Modifications that i will explain later , the Driver must reduce 10-15 Kilos too :rolleyes:
Sorry for my bad english , its not my homelanguage .
Here a link to my german diary : Das 100 MPG Projekt
kind regards Rd.
pete c 06-09-2013 12:32 PM
Welcome, rubberduck. Looks like a good project. I wish we had the assortment of small diesels in America that you do.
+1 on that 10-15 kilo mod you mentioned. I need to do the same. And your English is plenty good enough. Wayyyyyyy better than my deutsche.
Flakbadger 06-09-2013 01:33 PM
Welcome to the forums! It looks like you have a nice little car for hypermiling and sounds like you are on the right track, except HHO is proven to be false.
If you search the Ecomodder website and read about HHO, you will find many examples.
As for the driver 10-15 kilo weight reduction, you will find you get many more miles out of him as well :)
Take it from someone who lost ~20
Anyway welcome, and don't worry too much over your English. You seem to do quite well, and everyone here is friendly and understanding.
~Matt
mikeyjd 06-09-2013 01:53 PM
welcome and good luck!
Rubberduck 06-09-2013 04:34 PM
Hello and Thanks for the Welcome .
well Right the driver lost since January 14 Kilos , but his weigth is today 15% from the Car , thats a little bit too much :rolleyes:
About HHO we will see the facts if i install it and drive some weeks . our experience is different , Older Cars with lower efficiency runs better and with higher mileage . newer Cars have often Problems with it , the Motormanagement in stock cant work with it . so can the cars losing Fuel mileage .
but there are more complicated Ideas to solve.
The Standard Ways i must drive are much uphill downhill real much braking , there is a idea to build a mild hybrid from the car with a 3 or 4 kw electric motor that can recuperate break energy and at the other side help the machine to accelerate or drive some Miles only with Electric Power . i think it´s possible with low budget and some workpower .
Rubberduck 06-22-2013 10:13 AM
Today the Tacho turned the 300000 km , i am really Proud for this little Car :-)
http://3.bp.blogspot.com/-imMWgAKApS...600/300000.jpg
The last full Tank was enough for 1125 Kilometers . I Think now i am unter 3,5 Liters :cool:
NachtRitter 06-22-2013 03:01 PM
Hallo Gummi-Ente! Herzliche Grüße aus Kalifornien! I think before any major mods to engine or body, practice as many of the tips listed here 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com as you can
Rubberduck 06-23-2013 11:20 AM
Hallo NachtRitter herzlichen Gruß auch nach Kalifornien . :-)
i have read the 100+ Tipps and practice some of it . only the Scangauge i cant do in this Car m because no OBD2 , no Electronics .
Some Ways ich can Pulse , some ways downhill roll with motor off . ist like a Game to lower consumption . but not easy everyday . the Car ist the Daliydriver and some Kilometers with Wife , 3 Kids and full baggage .
now will make the lowering sprins and wheelbearings new , them see how it roll .
kind regards , die Gummiente
HypermilerAX 09-25-2013 03:13 PM
What's up?
Did you already lowered your AX? I'm interested in doing this mod. What type of springs did you choose? Short springs exist but I heard that the car could be too low with the heavy cast iron diesel engine. Someone got -90 mm with -45 mm springs installed on his 1.5D.
Rubberduck 09-27-2013 03:36 PM
Hi Hypermiler AX
No i havent lowered it , there was no Time for build anything , only Time für family , job and driving much Kilometers .
My springs are from H&R -45mm . i think with the Ironcast machines more lowering .
i´ve seen your last consumption at Spritmonitor . very Nice :thumbup:
my Ax will stay in the garage for the coming winter , there are much things to repair and modifie
the Gearbox makes some Problems and must be rebuild or changed . The Clutchbearing must also be changed . and many other works .
by the way , what do you think about the Peugeot 206 1,4 hdi ?
kind regards Rubberduck
Rubberduck 04-05-2014 07:39 AM
Back in the Ecogame
1 Attachment(s)
Hi Ecomodders
I had to change the plans for the winter , the AX had a hard Life the last half year . So there were no bigger modifications , only Kilometers with the Wintertyres .
The actually milage is 331750 Km and it runs reliably . Only the starter was broken, so I drove the car about 3 months. I always had to watch the I park so that I could let him roll on , had no money and time for repair .
Now the 145/80-13 Michelins are mounted, the air pressure is 3.3 bar and the car rolls very easily so . the only modifications are the taped flat hubcaps, reducing the weight of carriage by 21 kilos and Driver's 16 kilos .
The last consumption were 4 liters with 4 passengers and mostly highway driving with 120 to 130 Km / h. The current tank is again driven in economy mode, looks good so far. Only the longer 5th Gear Ratio i cant get by my partdealer , so i search more . Here an actually Photo ok the AX
best regards Rubberduck
HypermilerAX 04-05-2014 09:12 AM
Why didn't you keep the spritmonitor log up-to-date ?
Rubberduck 04-05-2014 11:44 AM
had too many other problems , lost some receipts and was too lazy to recalculate all :o
Rubberduck 04-18-2014 04:55 AM
2 Attachment(s)
http://3.bp.blogspot.com/-10yR5NBpt_...600/333333.jpg
I am a little bit proud for the Car ;)
Actually i am testing the HHO cell in the car , must find the best setting . Here is a little film of the cell : https://www.youtube.com/watch?v=BqgMKNtuNcA
and in the attachments pictures of the Cell in the Car , the dockingstation and the air filter cover with the hoses .
the 47x32 gears i have found but very expensive , can buy them in may .
Actually i am preparing the lowering springs and the wheelbearings , will install it after the hho test .
regards and happy easter to all .
Rubberduck 05-04-2014 07:16 AM
Had to find the best settings for the Cell . Last consumption 3,09 Liter/100Km
was perhaps randomly !? or perhaps the Cell !? ;-)
best regards
Rubberduck
Rubberduck 06-21-2014 08:17 AM
3,05Liter/100Km with a car in catastrophic technical condition ........
