Old 05-22-2010, 09:38 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
exhaust mod idea
if freeflow exhaust gives more performance, how about a super restrictive exhaust, maybe with one of those tractor flaps with a small spring to hold it close tighter. less crankcase venting wil work like an egr.
Then you need some 1/2 or 3/4 inch emt tubing and from the back run it to the intake for the ultimate EGR mod.
this way, the extra pressure on the exhaust forces more exhaust gas into the intake, kinda like the exhaust fed back into the intake but the springloaded flap will allow some exhaust to escape and allow some fresh air to be sucked in
Seriously though, what would increasing the backpressure do?
Old 05-22-2010, 09:52 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Increasing back pressure will increase "pumping losses."
Old 05-23-2010, 05:44 PM   #3 (permalink)
Backpressure itself does not do anything good for your fuel economy, your performance, or your engine.
Exhausts that produce backpressure under some circumstances can improve your fuel economy, or your performance. For FE, though, the gains are likely really tiny.
-soD
Old 05-24-2010, 01:14 AM   #4 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Um, I do need to jump in here (in my mind, anyways). Backpressure and exhaust port velocity are different. Understanding this concept will debug your mythological gains by blocking off of the end of your exhaust pipe. You could gain some mpg, possibly (there are many other things that come into this equation) by making your own exhaust head pipe with small diameter tubes (and a tri-y, stepped construction). Just a thought...
Will an Exhaust mod help fuel economy? morkys EcoModding Central 39 02-11-2013 09:22 PM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Diesel eco mod intake idea? nubbzcummins EcoModding Central 11 01-01-2010 02:48 PM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
Cruise control mod idea rjacob DIY / How-to 18 07-29-2008 11:27 PM
