That V-dub looks slick! - and I'm not just talking about the airflow! :p
The dust after the RV seems to mimic what snow does to a car while driving after sitting overnight. |
V-dub
Aerohead, on the XL1, do you think the bottom of the rear end is angled up too steeply? It seems the angle goes up too much, too fast and it will make the air collide with itself.
bottom
Here is an hot-link wrapped in URL tagshttp://www.shining-wit.net/rick/buggy/overview/dust.jpg Here is the same hot-link wrapped in IMG tagshttp://www.shining-wit.net/rick/buggy/overview/dust.jpg I can't figure out links to videos. |
hot link
Thanks freebeard for the hot link! It's way better than having to click on things.
'Hot-link', at least as I use it refers to offering the URL of an image on an external website, rather than an album under your control. It's quick but it's trusting the external site to not remove or change that linked object. I thought I had a bookmark to a good defense of the practice, but it doesn't 'fall to hand'. Until I find it here's a page where you can see people argue whether it's better to steal and repost the picture or just steal the bandwidth.
You can see the result if you experiment in the Preview window. You don't have to post it. Here's the same URL wrapped in Quote, Hyperlink and the Image tags. http://ecomodder.com/forum/attachmen...p;d=1261602367 http://ecomodder.com/forum/attachmen...p;d=1261602367 On-topic: Notice the way there's a solid stream of dust carried over the top of the front tire from the rear, then blown back along a nice template curve? |
stream of dust
Mercedes-Benz tested cars both ways and discovered that enveloping the wheels inside the saloon body,while increasing the frontal area,nevertheless,lowered the overall drag. GM did this with their OLDS AEROTECH LSR March Indycar chassis in 1987. The streamliners (enclosed wheels) always get higher speeds than the lakesters (exposed wheels) for a given horsepower.Better mpg too! |
That's why they have classes. :)
Accepting the limitation is what makes it art. What I'm thinking of is a belly tank with the VW boxer cylinders and heads sticking out of the nose like a light-plane with no propellor, front wheel drive like the XR-3, long axles with tall, narrow, rock-hard front tires for traction, a reclining cockpit like an F1 car, and the two rear wheels in tandem, (like the Speed Demon has in front). If you could get any traction, it would go real good. If the rear wheels need to be open, it could be done similar to the Junker G.38 landing gear. http://upload.wikimedia.org/wikipedi...itz-0128_5.jpg _____ Edit [20131012]: Like this http://ecomodder.com/forum/member-fr...belly-tank.png This is not well developed, yet; the proportions of the tires to the body are eyeballed, etc. But the idea basically is to have the same cross-sectional area as a P-38 tank (36" dia), but since I don't like the idea of a circular cross-section so close to the ground, it's more triangular, like a shark or ME-262. The flat-4 boxer is in the front with exposed cylinder heads and a corrugated dry-sump tank for an external radiator. There is zero internal ducting. The front tires are on 33" wheels with open spokes, but with a V-shaped rim like bicycles use. This is to improve cross-wind performance. The VW transaxle would be inverted to put the axle centerline above the crankshaft centerline (this saves needing to flip the ring gear). The rears are on an independent truck that is torsionally sprung. I roughed in a Golden Submarine-style turret but I suspect that forward vision would be video on a head-mounted display. Driver is to the rear so they can tell when they're driving sideways. |
