02-23-2015, 09:01 PM
...beats walking...
Aero drag information & data
Something for AeroHead: parasitic drag article
The Following 4 Users Say Thank You to gone-ot For This Useful Post:
02-24-2015, 01:03 AM
Thanks for pointing it out, but I'm not seeing much there.
It is almost impossible to
calculate the effect of these fittings, consequently only
rough approximations can be made.
True that.
All right, now we have the drag force on the wires
and struts but, to make good use of this knowledge, we
should equate this to the amount of power required to
overcome this resistance. To put it another way
"how much hp is this going to cost me?"
From F=kDLV^2 there's a hop. skip and a jump to HP = kDLV^3/375 with no consideration to interference drag, area rule, integration of composite shapes, etc.
02-24-2015, 12:09 PM
...beats walking...
freebeard, "true," but it sure is nice when someone else does the work and makes the results freely available for others to see & use.
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
02-24-2015, 05:37 PM
hop skip and jump
True that.
If we want to get into this,Hoerner's 1951 book has everything we'd need to approximate drag as close as aeronautical engineers were doing circa WW-II.
Also,the book 'TECHNICAL AERODYNAMICS of 1935 has complete workups as well.
It's no cakewalk,but it is doable.
Reason: spelling
