Battery replacement for personal device
1 Attachment(s)
I have a 2014 Edition Samsung Tablet 10.1 (SM-P600). I have had it since it came out in Oct 2013. It is a heavy use item for me. I do not have a phone.
I am refreshing it rather than replacing it because I can upgraded the memory, replace the cracked screen, and install a new battery for $80. And I get to learn stuff. BUT the battery I bought has a serious problem, unfortunately. It can hold a charge better than the 2013 OEM battery, but it it charges very slowly and the charge monitor has a red "X" over the battery icon the entire time. It is not the fault of my charger, the connection, an outlet, or the device. I know this because putting the OEM battery back in gets rid of the red "X". So the problem must be in the battery chemistry or the "pack" assembly. I cleaned the connector using MAP sensor cleaner. No change. I think I can eliminate the chemistry as the problem. If the chemistry was bad, wouldn't it fail to hold a charge? So I suspect that somewhere in the battery pack there is a bad connection. Does that sound reasonable? I wonder if I could mend it with a soldering iron. Your thoughts? Here is a picture of the battery pack (not mine, just an online stock photo): http://ecomodder.com/forum/attachmen...1&d=1498344070 BTW, don't buy batteries from "Battery Monster" that company's return and warranty turns out to be no better than a con. |
Do you have a pinout for those three pairs of wires? I'm not sure how you measure the internal resistance of a battery. But you appear to have two circuits to compare.
I've had similar experience. I don't carry a panoption phone, but I got the Barnes & Noble Nook tablet when it came out. It was a front-end for their store as a loss leader, but it played MP3 and showed JPGs so I was happy with it. Then the battery went out, but instead of replacing it, I got a new one because they are now down to $50. But the registration process to even boot it up was so onerous it's sitting in a box unused on a shelf. So I said at least I got a new power brick (I'd had two fail) and they're $25. But then I see a news story that the power bricks are being recalled because fire hazard. I'd just try again with a different company. |
Way too much work. You can get new tablets on closeout for about $100.
In which case, recycle responsibly.
EDIT:Check this out. Here is some fine soldering. Here is a dude fixing my model tablet's battery connector by re-soldering. The video is grainy from magnification and shaky. To see how the job starts and ends, compare 0:01 with 2:16. Wow. Subtle but clearly improved. I need a specialist if this is my problem. https://www.youtube.com/watch?v=PU0OoZSbma8 |
https://slickdeals.net/e/9284123-100...archBarV2Algo1 |
I'm refreshing what I have. |
The 8" has better specs for $133. Still probably not as good as your Samsung though. |
Still, it's funny how suddenly, in the last couple years, since the time of the iPhone 5, the devices have seemed basically to stall in their rapid technological improvement, you know? Moore's Law seems to be faltering. I am kinda amazed and happy at how long some of these devices are remaining competitive in the capacities that matter to me. I did look at the newer Samsung tablets and they are significantly better than mine, but not radically so. And they add creepy features, like a home button that constantly reads your fingerprint (!). |
I'd be tempted to disassemble it and use the circuit board of the original battery with the cell of the replacement.
