EcoModder.com
-   -   Battery talk (https://ecomodder.com/forum/showthread.php/battery-talk-35109.html)
jcp123 04-24-2017 09:15 PM
Battery talk
So, I bought a '97 Civic to replace my Echo. Battery is weak. Ironically, I'd just bought a battery (a good one, no less) for the Echo, but it won't fit in the Honda's little group 51 slot. So, that's a sunk cost.
I've heard about some of these lighter weight alternatives to lead-acid batteries, and I'd like to start educating myself before I need one for the winter. Point me in the right direction?
Stubby79 04-24-2017 09:50 PM
Braille makes light-weight batteries. Your choice of chemistry. https://www.braillebattery.com/
There are other/no-name brands of 12v lithium car batteries. Just make sure you educate yourself as to their winter performance and their reserve capacity.
There's also super-capacitor starting-aids for starting off of small batteries.
Google and possibly ecomodder search are where I'd start, now that you know what to search for.
rmay635703 04-24-2017 10:12 PM
With a little elbow grease you can probably make it fit.
If your cheap I use a $15 lawn tractor battery in several of my cars, you need to replace it more often but still cheaper than the correct battery long term.
jcp123 04-24-2017 10:13 PM
Winter isn't bad in East Texas. Lows in the 30s and 40s with occasional stints in the teens and 20s. More important is the fact (shoulda mentioned this) as a trucker, it's parked for a month at a time, though as a matter of course I disconnect the battery when it's parked.
I know little about battery chemistry and its properties, advantages, and disadvantages.
elhigh 04-24-2017 11:07 PM
Spend a few extra bucks and install a battery disconnect to take some of the hassle out of reconnecting the battery. Pop the hood <twist> drop the hood.
jcp123 04-24-2017 11:38 PM
Eh. 10mm socket on a ratchet isn't a big deal. But I like the idea of potentially longer life along with less weight over the front of my front wheel drive car.
Frank Lee 04-25-2017 12:29 AM
Leave it connected after adding a solar trickle charger?
oil pan 4 04-25-2017 12:34 AM
LiFePO4 batteries suck in the cold and if you charge them while they are below +20°F they are permanently damaged to the tune of a 20% capacity loss.
Also under hood temperatures can damage them.
They should be located away from the engine compartment heat.
I relocated mine to inside the vehicle and put them on a forklift quick disconnect so I can take them in on cold nights
jcp123 04-25-2017 06:49 PM
Still looking around. The temperature thing is a bit concerning. Weather here is unpredictable enough that it could get that cold, and in summer it can definitely get hot.
Starting to get a tiny bit discouraged. The Civic I bought is so clean that I'd feel bad messing with terminal ends, etc.
rmay635703 04-25-2017 08:10 PM
Fleet farm has plug in / bolt on battery adapters of all types along with knob style battery disconnects
I would still go for the $15 battery, given your circumstances even a lithium battery could overdischarge becoming an overpriced boat anchor, Franks solar trickle charger idea is a good one
For a 4 banger the little lawn and garden batteries pack a punch
Good luck
