Been lurking, finally biting the bullet!
I've been lurking the ecomodder forum on and off for a while now, utilizing some of the driving techniques and admiring some of the work done in order to crank out the MPG's!
I've recently shifted from a 7mi daily commute (3.5mi each way) to over a 240mi daily commute... needless to say, I've parked the truck, and have been logging 1200mi per week on the Acura instead. currently the Acura has antenna delete, suspension dropped (lowering struts/springs) but nothing else. I've been monitoring the fuel consumption via the BHP Torque app (with bluetooth obd2 transmitter) and have had an LTA of 29.9mpg varying from 26.6-34.2mpg per tank depending on driving conditions and driver habits. Ideally I'd like to get that number over 40mpg for my commute. future mods in store: full (removable) grill blocks LRR tires rear belly pan weight reduction (pass seat, rear seats etc) smooth wheel covers tire spats rear wheel skirts manual vtec over-ride more stringent driving techniques any advice, tips would be greatly appreciated. I'll be starting tomorrow by doing the grill blocks! |
Im going to see this week end how smooth wheel covers work on my 99dodge ctd I will also have a grill block. good luck on your MODS
Why vtec override? If you drive mellow, shouldn't it be possible to keep the vtec from engaging? |
I went the opposite way, but not quite as long a commute. I had only a 45 mile daily commute and now I"m down to a 14 mile commute and I gained an hour of my life back every day and would never go back. I even had the opportunity to go back with a substantial raise and wouldn't do it. I'm much happier with my short commute and actually having a life. |
welcome! if you do keep commuting, buy a highway honda; crx hf or civic vx type of thing, my two cents.:thumbup:
You might do well looking into a diff F series trans to swap into for longer gearing. CL's if I remember right were supposed to be "sporty" compared to the accord. I have had 2 of them. Decent cars but slow as dirt (4cyl) and terrible auto trans (3.0)
As for the grill block, it was/ is my intention to use 4 segments of coroplast attached via industrial velcro w sticky back, but i ended up using a $4 roll of black duct tape to get some preliminary results before spending $30-40 on the coroplast stuff. I should be done with those findings tmr. The first 120 miles ive noted a 10-15 degree increase in coolant temps at 205-210f vs 190-195f without. (Still in safe operating range) but with a minimal increase with intake temp running at 85-89f as opposed to 83-87 on similar cool mornings. I'll post back this eve or tomorrow after i see how the CLaero handles the afternoon temps with the full block. |
240 mi/day is extremely unfortunate. Time and money down the drain!
I'd strongly recommend spending your time sorting out your work/life arrangement rather than spending time on the car! The True Cost of Commuting | Mr. Money Mustache |
Yes, making arrangements would be ideal but it's an uncle sam kind of thing... I don't have much say in where they station me.
Good luck! |
nBleak21, I understand the problem , check with Billiting dept on your post,it maybe that they could use a strong back for 1,2,3,hr a day in exchange for a room , my post here has a small campground with overflow space for trailers no hookups 10bucks a night, buy a cheep trailer, check on working a modified schedule for a longer weekend.
I'm stationed at an FMS shop about 30min away from the nearest post with billeting, which at $15 a night (plus $5-6 in fuel every day)... i just can't justify for the living conditions vs the $30 in fuel a day($9-10 additional) to be back home in my own bed with the woman i love every night.
I dont mind the drive, actually rather enjoy it in some regards, as stated by California98civic... so i'm more or less just doing the mods for fun and long term fuel savings. |
To be young and in love again,your field maint. shop should have a shower,locker room,tv, microwave and a hidden corner that you can crash in,then you would be more rested ,save some $ and have a weekly honeymoon. a win win (Im OLD
I couldnt imagine losing 4 hours driving to and from work everyday...i spend about 20 mins so i guess im lucky...
A cheap mod for keeping the rpm down on the highway is get some narrow tall tires...the speedo will be off but it should help you mileage |
