Benefits of drafting "dirty" trucks?
Forgive me if this has been covered before, but I couldn't turn up much with the search function.
While driving to work this morning, I started to wonder if there were any negatives associated with drafting trucks with aerodynamically-dirty loads (i.e., car carriers, flatbeds with equipment, class 8 tow trucks, etc.). I settled in behind an 18-wheel flatbed with an uneven load and did not notice nearly as much drafting benefit as with a normal covered trailer. Are the currents behind trucks with uneven loads potentially detrimental to my FE? Thanks! :thumbup: |
A flatbed or car carrier has less of a turbulence trail behind them compared to a van trailer. I can notice how drafting effects MPG's by monitoring my vacuum gauge. If I run a steady rate on the highway and then come up to a tractor/trailer traveling a similar speed, I can actually see my vacuum slightly increase when following behind.
And of course, some of us will tell you not to draft at all, since, as I'm sure you know, it's dangerous, :)
Mythbusters did a test on it.
100ft behind was something around a 20% gain in MPG, 50 feet was 30% about, and it scaled all the way up to 20ft behind with a grand total of about 43% gain in gas mileage. I forget what episode it was but I think it was this season, which is season 12. They used some big v8 american car. |
If I did a lot of cross-country driving (where it would make sense to make the effort to draft a lot), I might get a CB and ask ahead of time if I can draft. Some truckers are more amenable to this than others, but all appreciate being asked first. That said, I do draft at 75-150 feet (depending on speed) during my commute, for 2-5 minutes at a time. |
In any event, I haven't found it to be one of the sharpest knives in my fuel saving drawer - finding the perfect truck at the right speed for any significant length of time is quite rare. |
don't draft, end of story.
