Best aerodynamic curved line
BEST AERODYNAMIC SHAPE, CURVED LINE (low Cd)
I have a chaos is most correct. Original ecomodder template 1 http://i62.tinypic.com/2z6z71y.jpg Original ecomodder template 2 http://i62.tinypic.com/t6dwyt.jpg Original ecomodder template EDIT http://i57.tinypic.com/111m42a.jpg Original ecomodder template EDIT 2 http://i62.tinypic.com/taj706.jpg Original ecomodder template EDIT 3 http://i59.tinypic.com/2u7wy01.jpg Original ecomodder template EDIT 4 http://i58.tinypic.com/2pqmcex.jpg Original ecomodder template EDIT 5 http://i57.tinypic.com/2m4dh7q.jpg Original ecomodder template EDIT 6 http://i57.tinypic.com/jtpa49.gif solar car curved http://i61.tinypic.com/339ppbm.jpg best EDIT curved line template http://i61.tinypic.com/qqbxio.jpg http://i57.tinypic.com/v7qbl5.jpg BEST CURVED LINE...... |
Volkswagen
It is best CURVED LINE
best
Here are a few which Rolf Buchheim and his associates tested at 1/5-scale at Volkswagen,including their plan-view,along with their coefficients of aerodynamic drag. The 1922 Wolfgang Klemperer body http://i1271.photobucket.com/albums/...ntitled1_6.jpg The 1981 'Drop' body http://i1271.photobucket.com/albums/...ntitled2_6.jpg The 1981 'Blunt' body http://i1271.photobucket.com/albums/...ntitled3_6.jpg The 1981 'Flow' body (truncated tail) http://i1271.photobucket.com/albums/...ntitled4_6.jpg The 1981 'Flow' body (full body) http://i1271.photobucket.com/albums/...ntitled5_6.jpg They also tested the 1937 AVA G'o'ttengen Schl'o'r pilbug car @ 1/5-scale it was Cd 0.15 with a smooth belly @ 1:1 scale it was Cd 0.158 with a smooth belly @ 1:1 scale it was Cd 0.186 with a 'standard' underbody http://i1271.photobucket.com/albums/...ntitled4-2.jpg I don't have its plan-view scanned yet.Sorry. -------------------------------------------------------------------------- With 'features' drag,all the models would have a little higher drag (0.008 in the case of the Pilbug car). *Adding mirrors might add in the range of 0.015 (as with the Ford FUSION LSR car). |
1st-gen HONDA Insight
The smoke flow image from HONDA also suggests the same thing. http://i1271.photobucket.com/albums/...titled-7-1.jpg NOTE: If the car is not ballasted,with weight in the front seats,its body inclination may not represent what it will be when 'occupied' by the driver and passenger.If so,the flow would be more favorable.We'd need to get one in the wind tunnel ourselves,and check this. |
