EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   THE Best Coroplast For Flat Underbody Panels! (https://ecomodder.com/forum/showthread.php/best-coroplast-flat-underbody-panels-7660.html)
Blue Bomber 03-29-2009 01:39 PM
Been wanting to put a flat underbody on my MR2 for a while now, beyond just improving MPG (front end gets floaty at high speeds due to the low weight). I was looking at aluminum, but it gets pretty expensive, and can dent easily. A bit flimsy, too, if you want to keep weight down. Then I checked out plastic, which is much more durable, but would need to be thick to keep it rigid, which means even more expensive and heavy.
Finally, like most people here, I decided on coroplast, which is cheap, lightweight, and durable. The only negative is that the average campaign sign is pretty flimsy overall, and would need significant bracing behind it to maintain its shape.
Searched and searched, and I finally came upon the ultimate cororplast: polycarbonate!
http://www.mcmaster.com/catalog/115/.../84825kp1l.gif
I found it at McMaster.com, listed as noncorrugated plastic sheets (interesting, since coroplast = corrugated plastic ;) ). It's actually made for indoor/outdoor wall and roof construction. I bought a 12x24 test sheet, and it just came in yesterday. This stuff is extremely rigid compared to standard coroplast, yet just as durable (strong, but not rigid enough to crack). McMaster even says it's virtually indestructable! It's UV, weather, and chemical resistant, so it's ideal for outdoor environments and leaky cars. :p It's also clear, making finding mounting points a breeze once it's cut to shape and fitted in place. It's heat resistant to 250F, so you'd only need to put heat shielding around the exhaust area. This stuff might even work well as a grill block.
For anyone who's interested, it at McMaster.com's online catalog on page 2080, listed under "Indoor/Outdoor Polycarbonate Wall and Roof Panels". Of course, this would be more expensive than snagging some campaign signs when nobody's looking, but you can create an extremely professional looking setup with it that won't flap in the breeze.
TomO 03-29-2009 03:50 PM
Good find and thanks for posting the info.
Cd 03-29-2009 05:12 PM
Isn't " polycarbonate " what they used to encase Han Solo ? :P
Back on topic : Good find - thanks for posting .
SVOboy 03-29-2009 05:51 PM
How much do you think a full pan will cost you?
TestDrive 03-29-2009 06:01 PM
A 48"x48" sheet (largest they sell) is $35.52.
McMaster-Carr
tasdrouille 03-29-2009 07:39 PM
If anyone stumble on a canadian source, please let us know.
eco_generator 03-29-2009 10:09 PM
Nice find. I think there is local one, maybe I can just pick it up. :)
cfg83 03-29-2009 11:10 PM
Cd -
Back off topic. You're thinking about carbonite as a containment matrix for tibanna gas :
Carbon freezing - Wookieepedia, the Star Wars Wiki
http://images3.wikia.nocookie.net/st...o_cut_away.jpg
Carbon freezing is the process of freezing stored tibanna gas in carbonite to preserve it while it is being transported over long distances.
I was hoping to use tibanna gas instead of Nitrogen in my tires, but it's hard to get enough to fill one tire let alone four.
CarloSW2
Shawn D. 03-30-2009 10:17 AM
Originally Posted by Blue Bomber (Post 94684)
... interesting, since coroplast = corrugated plastic ;)...
No, "Coroplast" is a brand name. The sheet you are talking about is not corrugated, but is instead extruded cells. Corrugations are undulating waves/patterns in a single-thickness material, which is often bonded to other materials (i.e. cardboard). It's not the cells that make the cardboard or plastic corrugated, but the manner of making the cells.
Bicycle Bob 03-30-2009 10:51 AM
Canadian Content
It is popular for greenhouse and patio glazing. Check your local building supply or garden shops.
