EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   BEST + CORRECT Aerodynamic FRONT (https://ecomodder.com/forum/showthread.php/best-correct-aerodynamic-front-33690.html)
slipknotsv 04-14-2016 05:26 AM
BEST + CORRECT Aerodynamic FRONT ;)
http://i68.tinypic.com/smzfy9.jpg
http://i67.tinypic.com/2ldy2h3.jpg
http://i65.tinypic.com/2hhpqow.jpg
http://i65.tinypic.com/2nu87qa.jpg
test 1 0.12
http://i68.tinypic.com/28vabnl.jpg
test 2 0,13
http://i63.tinypic.com/2i07uw7.jpg
slipknotsv 04-14-2016 10:57 AM
good...........
http://i63.tinypic.com/apcnzn.jpg
freebeard 04-14-2016 12:17 PM
You are focusing on the loft line (profile) and ignoring the wheelwells.
In turns the top of a tire doesn't move in/out as much as the middle of the wheel/tire. A uniform radius from the resting center of the wheel is sub-optimal.
http://i.imgur.com/1k1yDOh.jpg
slipknotsv 04-15-2016 04:28 PM
that it's nose is nothing remarkable,although it does have a complete boat-tailed rear. :thumbup:
freebeard 04-15-2016 07:48 PM
Or maybe it's a bluff nose with a low stagnation point, and a rear end that is too fast—intentionally, to improve cooling air intake—but too fast none-the-less. The narrowed front axle is good prep for front wheel skirts.
What a corrected Beetle body might look like.
http://ecomodder.com/forum/member-fr...four-tails.jpg
aerohead 04-16-2016 01:17 PM
nose
here is some data from R.G.S.White at MIRA,1969,
look at plan and elevation
http://i1271.photobucket.com/albums/...titled1_39.jpg
if you take all of his best of each category you get Cd 0.245 (in 1969)
http://i1271.photobucket.com/albums/...2/12-062-1.jpg
here's some windshield data from FIAT
http://i1271.photobucket.com/albums/...titled3_24.jpg
cowl height
http://i1271.photobucket.com/albums/...titled2_25.jpg
and nose
http://i1271.photobucket.com/albums/...titled1_25.jpg
front lift
http://i1271.photobucket.com/albums/...titled2_23.jpg
from Fachsenfeld (KAMM)
http://i1271.photobucket.com/albums/...2/scan16_1.jpg
Hoerner
http://i1271.photobucket.com/albums/...d2/scan5_2.jpg
Eiffel
http://i1271.photobucket.com/albums/...d2/scan4_2.jpg
Eiffel
http://i1271.photobucket.com/albums/...rohead2/-1.jpg
Walter Lay,1933
http://i1271.photobucket.com/albums/.../Scan03-22.jpg
slipknotsv 04-16-2016 04:06 PM
Big thanks Aerohead :thumbup:
Frank Lee 04-16-2016 05:04 PM
http://i146.photobucket.com/albums/r.../condomcar.jpg
http://i146.photobucket.com/albums/r...r/stiletto.jpg
http://i146.photobucket.com/albums/r...adonna-bra.jpg
http://i146.photobucket.com/albums/r...turliner11.jpg
One of these is optimal but I'm not sure which. :confused:
freebeard 04-16-2016 06:25 PM
aerohead -- So I try to get by with a rerun, and you throw out a whole bunch of new stuff. :thumbup: I think I'd seen only the last two before.
The first one is fun! For the Beetle, I get A-2 B-2 C-1 D-1 E-7 F-1 G-6 H-4. Is there a secret decoder key?
Frank Lee -- It's a setup. You want us to have to admit it's that first one. :eek: I'm going to go with:
http://i.imgur.com/VDbz2.jpg
It's all about the fineness ratio.
Frank Lee 04-16-2016 06:29 PM
Fineness ratio? I thought it was about fuselage length.
