Best Geometry for a Reverse Tilting Trike
Best Geometry for a Reverse Tilting Trike #6
The geometry is for a 4 meter wheelbase but is generalizable. Or maybe a tandem two-seater. |
Clear and accurate testing is always welcome. Equal length parallel suspension arms give the tilt geometry. Camber at 0 is fine. The Caster on the early Chevrolet Monte Carlo was 11 degrees tilted to rh rear. Positive or Negative castor works. Our motto is test don't guess.
