Clear and accurate testing is always welcome. Equal length parallel suspension arms give the tilt geometry. Camber at 0 is fine. The Caster on the early Chevrolet Monte Carlo was 11 degrees tilted to rh rear. Positive or Negative castor works. Our motto is test don't guess.
