Old 11-26-2013, 04:20 PM   #1 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Tire pressure set lower, MPGs went up? (Winter thread)
For most of the trip legs out of 11.7 miles today, I was getting rather low MPGs partially due to high tire pressure (About 55) and then I stopped at the gas station and set the tires to 46 all around; Then, For the trip home I got the highest MPG figure all day and I did feel more confident about accelerating at higher engine loads; It also helps that I can accelerate at all since I had trouble going up hills earlier! However, This isn't an A-B-A-B test on the same leg of road. But, I thought I'd share the thought.
Old 11-26-2013, 04:26 PM   #2 (permalink)
According to Darin's testing, 46 to 55 psi shouldn't make a huge difference is rolling resistance (obviously it differs from tire to tire, but still should be an okay general rule). I'd be more likely to blame a tail wind or something.
http://ecomodder.com/forum/showthrea...tire-2721.html
The Following User Says Thank You to Daox For This Useful Post:
101Volts (08-16-2014)
Old 11-26-2013, 04:53 PM   #3 (permalink)
There's a reasonable chance that it was something else that changed and improved your mileage. But it's worth a re-test, I think!
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
Old 11-26-2013, 05:10 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Engine temp with the candlestick in the dining room?
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
101Volts (08-16-2014), War_Wagon (11-26-2013)
Old 11-26-2013, 05:40 PM   #5 (permalink)
101Volts's Avatar
Yeah, It's far from A-B-A-B testing and the van started at about 30 FWT. Though I can say with 55ish PSI, I did not accelerate very well in that snow with the methods I tried and setting it to 46 gave it more traction and it made it feel about the same as the day before.
And jakobnev, I'm not sure what you mean.
Old 11-26-2013, 06:04 PM   #6 (permalink)
MPGs
According to published findings by SAE,an automobile is not fully warmed up until after 22-miles of continuous operation at 50-mph.Only then can you BEGIN testing.
101Volts (11-26-2013)
Old 11-26-2013, 06:59 PM   #7 (permalink)
High tire pressure and wheel slip in the slick weather, or didn't you get what we got in NEPA?
The Following User Says Thank You to Mad Adder For This Useful Post:
Old 11-26-2013, 08:36 PM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
This.
I've been keeping an eye on my fuel usage per hour at idle, and I don't drop to regular summer usage until after 15 min of coolant being 190+. Engine oil temp is my suspect.
The Following User Says Thank You to ksa8907 For This Useful Post:
Old 11-26-2013, 09:53 PM   #9 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
When I was running winter tires on my civic years ago I would get some wicked wheel hop while spinning due to ice and snow at 55psi, dropped it down to 45ish and the wheel hop went away. Traction during a slide may have gone up (butt-o-meter not any skid testing) but I did not note any significant difference in traction while not skidding (which matches the science I have seen regarding tire pressure and traction). Nor did I note any mileage change as during the winter road conditions and driver technique totally wipe tire pressure rolling resistance changes away.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
Old 11-26-2013, 10:50 PM   #10 (permalink)
101Volts's Avatar
I didn't know that, Thanks.
I did get slushy roads, The whole slipping thing is partially due to inexperience and, Frankly, Learning the hard way.
Originally Posted by ksa8907 View Post
This.
I'm now wondering if I should add more to the grille block.
What are some suggestions for engine insulation? I think Frank Lee made one out of styrofoam.
