Better.Bike PEBL
This is a new start up with a vehicle called the PEBL: A fully enclosed, four season, hemp based, pedal electric vehicle designed and tested in the demanding New England climate.
better.bike They have just begun a Kickstarter campaign, to raise $20,000: https://www.kickstarter.com/projects...dal-electric-v Price starts at ~$5,500, so right about what I'd expect. They are located in Leverett MA, which is relatively close to me, so I may be able to go see this for myself. 25 mile electric range standard, with up to 3 additional batteries, for ~100 mile range. Two seats, stowable doors. http://static1.squarespace.com/stati...pg?format=500whttp://static1.squarespace.com/stati...pg?format=500whttp://static1.squarespace.com/stati...pg?format=500whttp://static1.squarespace.com/stati...pg?format=500w |
Too wide to be a bike...and illegal in most of the world.
I'll take one. Just not at the price it would have to be to be profitable for them...
Cute. I expect to see them in trendy seaside areas and college towns.
They answered my question about how tall the driver of the PEBL can be - basically my height of 6'-4" is the tallest who can fit without mods. They have sold all the prototypes they built so far, and they are building another that they hope will be done by September. I am thinking about pitching in for their Kickstarter campaign, because I like their approach and design, and it is better in many ways than the Organic Transit ELF. PEBL has longer range and better materials. |
They don't want us to know how much it weighs or any dimensions, as the "specs" area on their site contains no specs. :confused:
Base specs: 6061 corrosion resistant aluminum frame with rear suspension Hemp & soy composite body Vinyl doors with zip up windows Full flooring with removable heel well inserts Impact resistant polycarbonate windows Programable 48v 750W power system 16ah Lithium Ion battery Fully adjustable cockpit (pedals, seat, handlebars) 20mph top speed 25 mile range (without pedaling) 5 Amp integrated charger (plugs into any standard wall outlet) Full street lighting (headlights, brake lights, turn signals, running lights) Reverse Cruise control Regenerative braking Horn USB charging port Keyed power switch Sturmey Archer 8 speed rear hub Sturmey Archer 90mm drum break front hubs Avid BB7 rear 200mm disk brake Oversized 2.3" Kenda K-Rad tires on Alex DM 24 alloy rims and heavy duty spokes 6 cubic feet of rear storage Transformable passenger seat for 4 cubic feet more rear storage 6 Standard Colors: red, orange, yellow, blue, green, white Dimensions: Length: 99" Height: 54" Width: 44" Track width: 42" Weight: 195 lbs Options: 600 watt heater Battery warmer wtih dashboard mounted temp sensor Additional USB/12 volt power ports 110W roof top solar panel Up to 3 more additional 16ah batteries for 100+ mile range per charge Interior lighting Wider tire and wheel options Custom coloring |
Bike lanes are a minimum of 1200mm wide, so that leaves 40mm per side. Dual purpose paths are narrower still. On a side of the road bike lane, you'll be constantly swerving into traffic to avoid drains and debris (not to mention always running on all the curbside broken glass), may not fit past the bollards that control access to dedicated bike paths, can't maneuver past stationary traffic (will have to sit there with the exhaust in your face). You'll likely get a lot of abuse if you try driving it like a car on the road, which is really your only option. I'm not opposed to this sort of thing at all, but it seems like a weekend fair weather toy. |
We live in the land of big- no worries.
660mm = 26 inches
There is no way to have the maximum width be just 26" on a trike for adults. I did a quick Google search and got 864mm width or 34", and 826mm or 32.5". |
Copyright ©2000 - 2019, vBulletin Solutions Inc.
