EcoModder.com
-   -   Better than a Kill Switch (https://ecomodder.com/forum/showthread.php/better-than-kill-switch-26712.html)
arcosine 08-17-2013 07:15 AM
Hi,
A few months ago Iowered the idle as much as it would go by plugging the aux air port in the throttle body. It idled at 600 rpm. Yesterday I found a hose disconnected, and now it doesn't idle at all. It's great! No more turning the ignition switch off and back on to coast, the odometer and ultra guage don't work with the ignition off. Now I need rewire the injector kill swich, the engine does't restart anyway without cycling the ignition switch, to a solenoid valve to let a little air in. It's hard to drive in traffic and parking with no idle. Im at 54.2 mpg for the first 350 miles on this tank and improving, Saturn SC1.
Sven7 08-17-2013 01:50 PM
So, let me get this straight. When you put it in neutral, it dies?
arcosine 08-17-2013 02:07 PM
Not only that, just press the clutch in.
Sven7 08-20-2013 01:38 PM
If it works for you, great, but I could see that being a big pain in the butt! Assuming it has to spin down before dying, making shifting gears possible? :)
whatmaycome14 06-26-2014 10:23 AM
I'd be interested in an update. Have you continued to allow this to happen?
