EcoModder.com
-   -   Big Bore throttle body for MPG? (https://ecomodder.com/forum/showthread.php/big-bore-throttle-body-mpg-4963.html)
cfg83 09-05-2008 06:15 AM
1 Attachment(s)
Hello -
I just saw this on e-bay :
eBay Motors: Saturn S-Series BIG BORE Throttle Body SC, SL, SW 91-02 (item 300256144389 end time Sep-11-08 18:42:01 PDT)
Attachment 1756
These throttle bodies are professionally lathe bored to ensure a precise and consistent bore
Not a quick and sloppy dremel job
Each throttle body is taper bored from the throttle plate out to 52mm on the front and back
Gain up to 12hp and Save Gas too!
Do you think this will help for MPG? My semi-edumacated guess says no.
CarloSW2
hondaguy72 09-05-2008 09:39 AM
No way it would save fuel. It gives you less control of high vacuum airflow over a smaller or standard throttle body. The only thing I can think of where that statement might be true is that the TPS values vs airflow would be different than stock causing a potentially dangerous lean condition. Very few aftermarket parts will positively affect FE.
Daox 09-05-2008 10:23 AM
Hondaguy72 is right. There is no way a larger bore throttle body will save fuel. In addition to what he said, the larger bore throttle body will decrease low rpm torque (increase higher rpm torque) which is the exact opposite of what we want.
I don't think you'd have a problem with lean conditions as the O2 sensor will ultimately correct for it.
cfg83 09-05-2008 01:30 PM
hondaguy72 and Daox -
Thanks for the feedback. I didn't think it would work but I didn't know exactly *why* it wouldn't work.
I think a lot of HP mods are just adding the "saves gas!" claim to all their stuff these days.
CarloSW2
bgd73 09-05-2008 01:47 PM
The saturn must have crazy delay timing wise to want a bore that big...variable valves or other gookiness.A dog chasin its own tail is very modern car , and inlines feed that crazy function..
A true stoich from timing at idle on up would not even need 75% of that bore...but that is today and gook injection and gook takin over the world. :rolleyes:
Visegrips announced it is moving to china.
nascarnation 09-05-2008 01:56 PM
Also looking at the ad, it appears to me like they are boring the casting but leaving the throttle plate (which is the real airflow restriction) untouched.
FWIW - S Sats definitely don't have variable valve timing (I've owned several - SOHC and DOHC).
aerohead 09-06-2008 04:18 PM
big bore
There is a "truth" to what they say,but it's taken completely out of context,as other members intuit,to capitalize on disgruntled motorists attempting gas saving mods.At WOT,the intake tract WOULD be closer to atmospheric pressure,so pumping losses would be reduced a fraction( less than an inch of mercury delta-P).BMW's attempt to remove the throttle body and entire intake(save for the air cleaner) tract,including the camshaft and conventional lifters,is a more visionary approach to reducing losses.---------------- I give the big -bore "the big Spanish Archer" as Burt Munro would say.A big thumbs down!
Ryland 09-06-2008 04:58 PM
ideal air velocity is around 300 feet per second, faster then that and you get restriction problems, slower then that and you loose torque and efficiency, it's similar to running to large of an exhaust pipe, if less restriction was the key then running without any air box and no air intake tubing would be ideal and everyone would have their exhaust exit the side of their car, but that is not how engines work best.
ATaylorRacing 09-12-2008 10:08 AM
From my own experience I can tell you that a slightly bigger TB can give more HP and FE. The TB in the E-bay add would do both, but NO WAY are you going to gain 12 HP! The throttle plate is the same as stock and all they are doing is cleaning up the air flow going into the TB.
On a bone stock 3.0 liter V6 Dodge Shadow/Plymouth Sundance from the early 90s going from the stock 42mm TB to a 52 or 56 one off a 87 mini van with the same, but older motor picks up about .25 seconds in the 1/4 mile and from 1.2-1.8 mpg (1.7 in my case).
On my 98 SOHC Neon I went to a HUGE Indy Cyl Head intake and the FE stayed the same and I lost torque, but gained higher rpm power...no improvement in the 1/4 either (advertised a 25 hp improvement with a bigger TB.....So I bought the AF/X 60 mm TB and picked up a bit over 1/2 sec in the 1/4 and FE became nearly 2 mpg better.
On EVERY car I have owned.....if I was cruising, any air flow improvements into the motor made more FE and power....on MOST a better flowing exhaust did the same thing, but not on the V6...a better flowing exhaust made it have worse power and FE until I did a lot more mods....the stock set up worked the best initially.
What I have found is that with the extra power you can drive up to your speed easier and maintain it with less throttle = better FE.
TELVM 09-12-2008 02:11 PM
Originally Posted by ATaylorRacing (Post 60774)
On EVERY car I have owned.....if I was cruising, any air flow improvements into the motor made more FE and power....on MOST a better flowing exhaust did the same thing ...
Similar experiences here.
Switching to an oversized TB sometimes brings drivability problems for street & road, however. Unless the OEM TB is clearly undersize for the application (rare), the TB is one of the last things I'd fiddle with in the intake system.
BTW any TB has some potential for improvement. Every bit helps:
http://img37.picoodle.com/data/img37...Dm_d047931.jpg
http://www.geocities.com/wilwaxu/TB_files/knifeedge.jpg
johnmyster 09-12-2008 03:39 PM
Air doesn't flow like that.
Formula413 09-14-2008 11:17 PM
I was wondering about that. Lots of people on LS1tech have their TBs ported, shaving off as much excess material as possible. But like you said, that means more air is coming into the intake manifold at any given TPS value. Although it probably is true that the O2 sensors can easily compensate. People who have this done talk of improved throttle response. Well of course, there is more air coming in for any given throttle position.
jonr 09-14-2008 11:51 PM
All this intake airflow stuff pertains to WOT and maximum output. Generally not applicable to moderate output operation and FE.
Vanner 10-25-2008 04:33 PM
I would think a SMALLER bore throttle body would help at moderate throttle positions, given that the air restriction would then "be" at the bore and allow the throttle plate to open up more for a given demand. Nascarnation nailed it: your restriction is at the throttle plate unless the plate is open.
jonr touched on this: for WOT there is no throttle plate and fuel economy should increase with a big bore. Great.
I see this argument as in a similar vane to CAIs, they say if you can reduce intake restrictions the engine doesn't have to "work as hard" (whatever that means) to cruise at some speed. Seems like rubbish, the throttle plate just chokes off whatever progress you make upwind.
Anecdotal evidence is evidence, I know, but there a hundred factors that go into fuel economy. And no one yet has installed a throttle body trying to save money.
Christ 12-30-2008 06:13 PM
Noone (that I saw) mentioned that adding a larger throttle body will do nothing but impede airflow...
Considering that the plenum it's bolted to is milled specifically for the size of TB that you were already running, and adding a larger bore without port matching it just adds frontal area inside the throttle bore, which will create a separate flow characteristic, which actually means that you'll ultimately have LESS air coming in at the same throttle position.
Using that throttle body without port matching the manifold for it will do absolutely nothing for you... at least nothing noticeable. You might lose power at high throttle angles though, due to the flow restriction.
Coyote X 12-30-2008 07:05 PM
On my ls1 camaro smoothing and porting out the throttle body made it get better mileage at wide open throttle so I think it went up to 3.1mpg or some other equally meaningless number. It didn't change the mileage at all overall, but it did let the engine rev quicker so it was even harder to launch the car off the line.
I suppose under an ideal situation you might get better mileage. But for the most part at partial throttle that big throttle blade is 99.9% of the intake restriction. Smoothing it will help very little unless your tps sensor is now reading a bit off and making the computer do something different.
Porting them is much easier than it looks so if you want to do it I would say just get a dremel and do the one you already have and save your money.
ATaylorRacing 12-30-2008 10:18 PM
All of this depends on the car itself. I mentioned earlier from a post I made on 9-12 that improved air flow made every one of my cars go quicker and get better FE....I was shocked that this was NOT the case on my 96 Geo Metro 3 cyl! Going from the stock air filter to a home made CAI and fine wire mesh for a filter made the car consistantly loose nearly 2 mpg on the hiway!!! Using the stock air filter but keeping the CAI made the FE worse than the stock set up by about 1 mpg too!
Christ 12-30-2008 10:42 PM
The idea is that even if you're at partial throttle, and have that huge restriction in the way, you're still flowing more air at the same throttle angle, meaning less VE (pumping) loss. Technically, this would give SOME improvement in both HP and MPG.
The fact still stands that a larger throttle body is never a bolt on procedure... you need to portmatch the manifold or you will get LESS airflow overall than the OEM config does, because you're introducing flow reversion at med-high throttle angles (due to the original TB port sized hole in the plenum.)
Reversion is worse than restriction, because restrictions slow down flow, but it's still positive... reversions attempt to "Reverse" flow, which isn't possible, so it creates a large area of turbulence in the flow, thus making the flow's cross sectional area smaller than the OEM config.
I still maintain that without matching the plenum to the TB, that "bolt on" mod will net you a loss of whatever it cost you, and probably less power/mpg as well, if there is any change at all.
ATaylorRacing - did you try just using smooth pipe and the stock airbox/filter? Or even using a smooth pipe w/ the stock airbox and a higher flow filter?
AFAIK, the most restriction present in the intake tract of most vehicles is the filter, second the airbox itself, and third the piping.. smooth piping sometimes helps, but isn't usually necessary. Filters are usually the best single piece to the puzzle.. so maybe a K&N or a Green filter will help out instead of hurting?
Putting a short ram on Granny did nothing but improve high-end HP... I have not noticed a lower MPG or less seat-of-the-pants torque at all, and the filter is right behind the radiator's flow path on the cooling fan side.
Peter7307 12-31-2008 08:12 PM
CarloSW2
Having been around the car modifications business for more years than I care to admit to I have seen more than a few items come back again relabeled to claim greater fuel efficiency.
"Shrouded" spark plugs are one example.
Previously they were touted to boost power (1960's) or reduce pollution (1970's) and from time to time they claimed both !
The packaging and marketing slogans have changed but little else has...apart from the warning dating back to the days of the Roman chariots racing around the Collusseum in Rome : Caveat Emptor = Buyer beware !
Cheers , Pete.
jazzie604 12-31-2008 09:44 PM
Taylor, are you sure that you just didnt change your fuel trims whel you were adding the high flow stuff? Several of the cars you listed were very archaic(sp?) computer systems that didnt have much compensation room built in. A properly functioning system should automatically adjust for minor changes.
