Big test of 5 LRR tires
With low RR tires becoming mandatory in Europe as of November 2012 (earlier in new cars), a recent issue of the Polish edition of Auto Bild (Auto Świat 34/783, 16.08.2010) published a test of five low rolling resistance tires: Bridgestone Turanza ER300 Ecopia, Goodyear EfficientGrip, Michelin Energy Saver, Nokian V, and Pirelli Cinturato P7. The tested tires were all 205/55R16, and were tested on a Mercedes C200 CGI, loaded with precise instrumentation, on a flat test track with no wind. All showed a reduction in fuel consumption compared to the standard tire (the article doesn't reveal what the standard tire is in this case). Fuel consumption was measured at three different speeds: 80, 100, and 130 km/h (50, 62.5, 81 mph).
Fuel consuption was not the only thing tested, the main focus was safety. First, the maximum aquaplaning speed.
Aquaplaning on a curve:
Driving on dry pavement:
Driving on wet pavement:
Braking on dry pavement (from 100km/h, 62.5mph):
Braking on wet pavement (from 100km/h, 62.5mph):
Driving in a circle (time for one lap, article did not give radius):
Rolling resistance (measured on a special machine):
External noise (average of tests @ 70/80/90 km/h; 44/50/56 mph):
Summary: The best low RR tire appears to be the Pirelli Cinturato P7, with Bridgestone Turanza ER300 Ecopia second and Nokian V third. Goodyear EfficientGrip and Michelin Energy Saver may have the lowest rolling resistance, but their performance is at the lower boundry of safety. Note: The article did not give details about the testing procedures, i.e. how many tries were averaged, etc. I pretty much translated the whole article, plus converted all units. |
Just "driving" doesn't say much ;) Quote:
It's OK in the dry though. I also use the wider 205 16" version, rather than the stock 195 15" . Driven acording to ecodriving / hypermiling principles, you shouldn't get into trouble. I've removed the original Energy 3 B (I think, could have been E3A) from the car because of their lousy performance - the wider Energy Saver is notably better than that. |
Did they mention what air pressure(s) they used?
But yeah, i totally agree with you. Higher pressure would reduce aquaplaning and even out treadwear. But that would reduce the amount of tires we'd have to buy and we can't have that!:rolleyes: ollie |
REmember this post:
http://ecomodder.com/forum/showthrea...-db-18989.html It also contains data from tires from "official" tests. I would add to your data also: http://www.goodyear.eu/de_de/images/...ive-report.pdf TUEV SUD report on: TÜV SÜD Automotive Tire Benchmark Test -2009205/55 R16 91 V: Wet & Dry Performance -Lifetime -Rolling Resistance/Fuel EconomyReport No. 76236753-2 Bridgestone Turanza ER300, Continental PremiumContact 2, Goodyear EfficientGrip, Michelin Energy SAver, Pirelli P6 Cinturato Ecoimpact. autobild sports car test http://www.carworks.gr/online/pdf/hankook_autobild.PDF http://www.unigum.pl/images/stories/...65_R15_91H.pdf http://www.bettertyres.org.uk/_uploa...yre%20test.pdf i have more data on pdf but i can't attach it because of kB limits in this forum, sorry Official tests and documentation from European Comission lots of info (there is important info hidden in the zips and endless and boring documents ): radius dependance of tire rolling resistance, rolling resistance of large sports tires being better than small "eco" ones, etc. all the test are anonimously so make and model comparision (or brands: van, car eco, car uhp, etc.) couldn't be done but its interesting. http://ec.europa.eu/energy/efficienc...f_tyres_en.htm http://ec.europa.eu/energy/efficienc...g_tyres_en.htm where you could find these working documents and analyses of tires, summary from independent test with assessments on specific tires (with make and model), etc: http://ec.europa.eu/energy/efficienc..._documents.zip |
This is great information! thanks! I plan to run a set of the Pirelli P7 Centurato tires on my GTI - see if I can get the average up to 66 mpg. :D
I find it really interesting that they document that wet traction is worse for the LRR tires.
It's almost a universal feature that LRR tyres perform less well in wet conditions. |
Interesting, but I'm quite puzzled by one comment:
