Biodiesel shelf life
B100 biodiesel (FAME, not the pure veggie oil stuff) apparently degrades over time.
Does anyone here have experience B100 that had been stored a long time - say up to and beyond half a year ? The last 6 months, I've used some 800L of B5 diesel. If I want to blend B100 and B5 to get B10, I only need 40L of B100 / 6 months - hardly worth the effort to go get it. |
http://www.biodiesel.org/pdf_files/f...yths_Facts.pdf
says 6 months, while a bio diesel forum I read said that the department of energy says it should last no less then 8 months and a year under good conditions. |
I used some stuff that was 6 months old, not stored in the best conditions, but not bad conditions, and it worked fine. FWIW.
Dave |
Getting a small stock when I get near a pump with good BD. It's not generally available here, so it takes some effort and travelling to get it. The small amounts I could add to a custom blend (I'd start with B10 as we're already using B5) means the B100 will stand for a while until all of it is used. |
Oh, I see! What vehicle are you driving? Please pardon my American ignorance!:D 47MPG is that all around commuting?
Thanks, Dave:thumbup: |
2011 Volvo V50 Wagon Quote:
Commuting, leisure, to the shopping mall, anything anyone would use a car for. |
Sweet! Can you run BioD in a '11 Volvo Diesel? More than B20?
Dave |
Engine manufacturer PSA (Peugeot-Citroën) sets the limit at B30 with DPF, if you also double the oil change frequency (due to oil dilution). |
