Old 01-28-2015, 02:02 PM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
30second 120kW battery pack
I am designing my EV battery pack to A8 project and target is to make 120 kW for max about 30 seconds acceleration (standing mile).
I havent yet decided about the motors but I could still need some help on the EV design specs. So battery should have minimum weight I have made some calculations:
Voltage 350-370V
P=120000W
I= 342A with that 350V
30s-->0,0083hours
C=342Ax0,0083=2,84Ah
With 20% margin that would need 3,5 Ah pack.
What would you recommend using?.
I would like to use something like these:
GTL Rechargeable 3.7V "5800mAh" 26650 Lithium Battery w/ Protection Circuit Module - Brown (2 PCS) - Free Shipping - DealExtreme
Tesla is still using 18650 type batteries?
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 01-28-2015, 02:18 PM   #2 (permalink)
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
Hi Vekke, that sounds very similar to a drag racing pack, but those cells you identified are low amperage devices. Here's one reviewer's quote.
"Delivers current up to 8-9 A without problems, then turns off the PCB."
You're only asking for 342 A, which seems small, but you'd still need to parallel almost 50 of these cells for that kind of current. Competitive EV drag racers aren't hitting the track with less than 2000 amps on tap these days.
Check out the National Electric Drag Racing Association forums. Most of those guys are either going LiPo or some proprietary cells by Derek Barger at
Battery Packs
Here's aother racing battery supplier, John Metric. He also races the standing mile.
ampahaulic.com
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
The Following 2 Users Say Thank You to jray3 For This Useful Post:
jeff88 (01-29-2015), RedDevil (01-28-2015)
Old 01-28-2015, 03:25 PM   #3 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
So limiting factor is max A batteries can push out.
Battery test-review 18650 summary
If I have batteries that can push lets say 30A. I would need:
11 pcs in paraller to get 340
+ 100pcs of those pack in series to get 370V
Total of 1100 batteries?
Is the math correct?
Old 01-28-2015, 03:58 PM   #4 (permalink)
Actually a chevy volt pack can do 380-400v & I've been to 600 amps on mine for 30 secs on monster hill. Not bad for $2500. You are going to be in a different neighborhood however.
Old 01-31-2015, 04:34 PM   #5 (permalink)
GreenHornet's Avatar
For something short burst of only 30sec look into Ultracapacitors such as the New Maxwell 3400F 2.85V Boostcaps. These are light weight and extremely powerful. Batteries will not give you the power that these can provide!
GH
