EcoModder.com
-   -   bla bla bla (https://ecomodder.com/forum/showthread.php/bla-bla-bla-28258.html)
yoyoyoda 02-22-2014 02:09 AM
bla bla bla
This forum steals ideas and claims them as their own!
http://ecomodder.com/forum/414618-post41.html
Don't join!
mechman600 02-22-2014 12:19 PM
I love projects like this! Keep 'em coming.
sjgrimsley 02-26-2014 01:50 PM
I'm curious how the new antenna does. Keep us posted.
Fat Charlie 02-26-2014 02:39 PM
1 Attachment(s)
Maybe like this?
http://ecomodder.com/forum/attachmen...2&d=1393443468
Now it makes more sense to me. ;)
yoyoyoda 02-27-2014 06:09 AM
1char
digital rules 02-27-2014 06:38 AM
Me too!!
yoyoyoda 02-27-2014 07:09 AM
1char
redpoint5 03-01-2014 11:17 PM
Do you notice a difference in acceleration or better handling with the reduced weight? 50KG is quite a lot, but I honestly don't notice much of a difference between just me driving, and driving with my wife in the passenger seat.
I just made an upper grill block out of white coroplast, and it looks good and is holding up well.
http://i7.photobucket.com/albums/y26...m/KIMG0019.jpg
I've left the top gap alone since it wasn't as easy to wedge the coroplast in there, and there needs to be easy access to the engine.
Half of the lower grill has been crudely blocked with pipe insulation. I might block the lower section off as well, since temps haven't been going above 185F.
Joggernot 03-02-2014 09:27 AM
Be careful when blocking both. My Accord worked very well for several months, but then started overheating. Learned that the blocking caused the old fans to run much more than they were used to and the fans failed. Had the expense of replacing fans...:(
yoyoyoda 03-02-2014 09:08 PM
1char
redpoint5 03-03-2014 03:24 AM
Originally Posted by Joggernot (Post 413334)
Be careful when blocking both. My Accord worked very well for several months, but then started overheating.(
I have an Ultragauge on both of the vehicles we're currently driving and keep an eye on the coolant temps. It's easy to tell when fans kick on because the temps will hit a max temp, and then rapidly drop until the low threshold. I haven't hit that yet in the Camry, but am quite familiar with that point on the TSX. I also have an alarm set to go off just before the the temps hit the fan threshold.
Originally Posted by yoyoyoda (Post 413484)
Yes definatley, If you didn't notice any change then I think there might be something wrong with your engine or transmission.
I feel that I have a good feel for any car that I regularly drive. I can tell the difference between 87 octane and 89 octane in my TSX, but strangely, I don't notice a single extra passenger. Add 2 or more, and I notice. Maybe I'm just accustom to a passenger.
We are talking about only 4-5% difference in weight, so maybe my butt dyno isn't calibrated precise enough. Then again, I would think the difference in octane would be on the same order of performance difference.
yoyoyoda 03-03-2014 05:45 AM
1char
Goldenstate 03-03-2014 10:54 PM
Thanks for the idea of reducing the amount of windshield washer fluid carried in the under-hood container. Never gave that a thought until reading your post.
I seldom use the windshield washer and may try removing the entire unit for more weight loss. Years ago we got along just fine without such luxuries and thought nothing of it.
yoyoyoda 03-04-2014 07:15 AM
1char
yoyoyoda 03-07-2014 10:34 PM
Solar panels on roof + Safari roof.
1char
yoyoyoda 03-10-2014 08:29 AM
1char
oldtamiyaphile 03-10-2014 10:57 AM
Originally Posted by yoyoyoda (Post 414203)
Seeing as its so hot here in Aus I'm thinking of making a pedestal ontop of my roof out of solar panels using flat brackets that I can bend myself out of sheet aluminium.
A safari roof/tropical roof is a second skin over the roof. The air between the two acts as insulation, keeping the roof cooler under hot sun.
What colour is your car? On my white van the area under the solar panel is much hotter than the surrounds, on a hot day I can touch the underside of the sheet metal that isn't covered by the panel, but the part under it is too hot (don't really have a good way of measuring unfortunately). I've got about a 12mm airgap between the panel and roof skin. The emisivitiy of white paint vs a black solar panel means even with 17% of the sunlight being converted to electricity, it's not enough to compensate for the darker colour.
If you've got a near black car it might just end up at the same temp, but on a light colour car, it will be hotter inside :(
My aim is for 400w of panels and an alternator delete.
samwichse 03-12-2014 11:45 AM
Somebody got told too much by their parents what a unique snowflake they were.
I didn't see any completely original ideas in this thread or the others. Moveable grill blocks? Antenna mods? Weight reduction?
RAGEQUIT!
RedDevil 03-12-2014 12:26 PM
My son has Asperger's.
Looks familar, this.
A shame, I so want to help that kid, like mine.
Xist 03-13-2014 05:37 AM
I have been on dates where the girls asked if I had been diagnosed with Asperger's. I thought that they had personality disorders.
We think that our dad has Asperger's. My brother is Autistic. I do not understand why women cry and why I am supposed to care. I just hate how many people still do not know what Asperger's is, they just start laughing at me.
"What kind of burger?!" [snort]
RedDevil 03-13-2014 07:04 AM
My son has not the slightest idea what other people are experiencing. My wife was ill a few days ago and went to bed early. He just cannot grasp that. He does not feel tired himself, then his mother cannot be tired?
At times he seems to display empathy, but we are never sure whether that is real or just rehearsed role play.
My son can also get angry on the slightest of issues and then there is no measure on his retaliation.
Luckily it is mostly words, but things like 'I want the whole world to die' (f.i. when told it is time to go to bed, after ample prewarning) show his lack of moderation.
What is fascinating is that he is able to deal with little disappointments most of the time, sometimes accepting them without any emotion whatsoever, or hardly a shrug. But gradually his display of emotions verges towards normal; nowadays he may also show slight disappointment about something, in a normal fashion.
We get help of course, but the insurance companies have dropped support for Aspergers lately for periods longer than a year; this was sanctioned by our goverment... We can deduct costs from the income tax, but the level is set high and depends on weird rules.
The bureaucracy and delays for getting additional help at school are horrible and exhausting. Enough to rant about.
We live in hope, fear and agony. We cherish the good days.
My son is a very nice kid and popular at school despite his problems.
My son knew the Greek alphabet at age 5, including the archaic letters. He is still in diapers (at 6).
How many parents have to change their kids diapers while the kid recites the Greek alphabet backwards, correctly determines the day of the week for any date in the past or future, ponders about the universe, etc...?
