Old 02-22-2014, 02:09 AM   #1 (permalink)
bla bla bla
This forum steals ideas and claims them as their own!
http://ecomodder.com/forum/414618-post41.html
Don't join!
The Following User Says Thank You to yoyoyoda For This Useful Post:
mechman600 (02-22-2014)
Old 02-22-2014, 12:19 PM   #2 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I love projects like this! Keep 'em coming.
The Following User Says Thank You to mechman600 For This Useful Post:
yoyoyoda (03-08-2014)
Old 02-26-2014, 01:50 PM   #3 (permalink)
sjgrimsley's Avatar
Trans Am - '82 Pontiac Firebird Trans Am
90 day: 20.84 mpg (US)
Explorer - '95 Ford Explorer XLT
90 day: 19.02 mpg (US)
I'm curious how the new antenna does. Keep us posted.
Fully sequential port fuel injection
406 sbc 350hp @4800 425lb-ft @3600
4L60e trans .70 OD, 3.23:1 rear, 26" dia. tire, 1,600rpm @55, 2,050rpm @70
Old 02-26-2014, 02:39 PM   #4 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Maybe like this?
Now it makes more sense to me.
Transmission type Efficiency
Old 02-27-2014, 06:09 AM   #5 (permalink)
1char
Old 02-27-2014, 06:38 AM   #6 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Me too!!
Old 02-27-2014, 07:09 AM   #7 (permalink)
1char
Old 03-01-2014, 11:17 PM   #8 (permalink)
90 day: 29.78 mpg (US)
Do you notice a difference in acceleration or better handling with the reduced weight? 50KG is quite a lot, but I honestly don't notice much of a difference between just me driving, and driving with my wife in the passenger seat.
I just made an upper grill block out of white coroplast, and it looks good and is holding up well.
I've left the top gap alone since it wasn't as easy to wedge the coroplast in there, and there needs to be easy access to the engine.
Half of the lower grill has been crudely blocked with pipe insulation. I might block the lower section off as well, since temps haven't been going above 185F.
Old 03-02-2014, 09:27 AM   #9 (permalink)
Joggernot's Avatar
Be careful when blocking both. My Accord worked very well for several months, but then started overheating. Learned that the blocking caused the old fans to run much more than they were used to and the fans failed. Had the expense of replacing fans...
Old 03-02-2014, 09:08 PM   #10 (permalink)
1char
redpoint5 (03-03-2014)
