EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Blackout or leave raw-Mazda CX-5 skirt brace (https://ecomodder.com/forum/showthread.php/blackout-leave-raw-mazda-cx-5-skirt-brace-32872.html)
kafer65 10-05-2015 12:33 PM
http://ecomodder.com/forum/member-ka...ce-distant.jpg
I can't decide which would be better. Do I leave the skirt brace raw aluminum or black it out to conform to the rest of the trim style? I painted the brackets with hard bed liner from rattle can in the back. It give a decent wrinkled finish that would be close to the arch style. What do you guy think?
LeanBurn 10-05-2015 02:25 PM
I vote black for a more finished look.
It's interesting to see the clear wheel skirt, has it become more dirty on the inside over time?
Xist 10-05-2015 03:00 PM
I say that you paint or plasti-dip it to match the tire, but leave the part over your rim bare. :)
euromodder 10-05-2015 03:53 PM
Match the car's paint.
kafer65 10-05-2015 06:52 PM
It gets dirty almost instantly when raining. The wheel covers are gradually dirty over about a month if it's not raining much.
Xist 10-05-2015 07:58 PM
Wheel skirt wipers? :)
botsapper 10-05-2015 08:10 PM
Always liked zoom-zoom design. Body color paint. http://i.imgur.com/r81SOZ0.jpg
Joggernot 10-06-2015 09:32 AM
I vote for the whole thing black.
Daox 10-06-2015 10:03 AM
Ditto. Blackout is my vote.
kafer65 10-06-2015 10:48 AM
Better?http://ecomodder.com/forum/member-ka...rt-blacked.jpg
Its much easier to put the brackets on first to be able to see through the material to line up to the complex fender curves to drill and mount from top to bottom. The lip depth changes a lot so most of the brackets are sized specifically for a certain location. They slide onto the lip near where the plastic lip is mounted to the car to reduce vibrations and sag. I'll need to modify the brackets for a set screw since I've already had FAIL on the front skirts sliding in unison into the well after catching on the tire. There isn't any room to have a bolt and nut clamp setup.
