Block Heater + Coolant Pump
Well, it's that time of year again... time to start thinking block heaters.
Circulation heaters typically work on the thermosyphoning effect where hot coolant rising out of the heater pulls cold coolant in, but this very slow circulation leads to an engine that is heated more on one end than the other and takes a long time to heat up. I bought a 1000W Zerostart tank-type circulation heater to install in my Cruze. I would like to install a circulation pump in line with it to speed up the warming process as well as heat the entire engine side-to-side a bit more consistently. Question: Has anyone here done something similar, and if so what did you use for a circulation pump? I have a drain pump from a dishwasher I'm planning to use but since I haven't started installing it yet I thought I'd ask around to see if there are better options? One thing to keep in mind is BUDGET... I know there are some pumps designed specifically for this but they typically cost 100's of dollars. This needs to be relatively cheap. One thing I though of would be a water pump from a small engine like a motorcycle or snowmobile, if such a thing were available as a separate unit that didn't mount to an engine block? Suggestions welcome! EDIT: Operating on 120V would be a nice to have as it would work on AC wall power along with the heater. |
Ebay? There are options for much less than "100's of dollars"...
Here's a 1.5kw heater with pump: Quote:
Tank Type Engine Coolant Block Heater Pump 1500W Diesel KAT'S Brand Tractor NEW | eBay You'd want a timer, too, obviously. |
Maybe a oil sump heater? You could get a magnetic or a adhesive pad type, the pad ones you could also stick to the engine block itself. Also, don't the circulation heaters have a pump built in?
Heh. I was wondering whether I could use the heating plate of an old coffee brewer as a cheapo block heater.
I meant to use it as a contact heater only, but maybe it can be used to pipe-heat the coolant too. Most likely I'll stay away from messing with it like this until the warranty has expired :o After all, I'm not that keen on using some home-built high voltage contraption in an environment that may have volatile and explosive gases. :eek: |
My "100's of dollars" comment was based on pricing replacement auxilliary coolant pumps out of luxury cars (Merceded, Lincoln, etc.) that use a pump at idle to keep heater core flow high, and also replacement coolant pumps for fuel-fired diesel engine heaters. Quote:
FYI
The dipstick oil warmer from Oreilly is junk |
What are the benefits of mechanically circulating the coolant?
I wouldn't think they are that huge... You're dumping 1000W into the coolant weather you pump it or not. Does it matter if the block is being heated evenly? As soon as you start the engine its going to circulate it for you. |
