Bluefin Tuna Template, is this it?
The Bluefin Tuna is one of the fastest long distance swimmers which translates as high efficiency. I haven't perfected the art of overlay, but here's my rough job below, I've included both pic's, so maybe someone can do a better presentation, looks like the Bluefin needs to be rotated slightly to the right.
Even with the rough job it looks pretty good to me, they also lay down all fins at speed into specially designed grooves. http://ecomodder.com/forum/member-te...a-template.jpg http://ecomodder.com/forum/member-te...uefin-tuna.jpg http://ecomodder.com/forum/member-te...template-2.jpg |
IIRC Bub speed record bike at .09 Cd was modeled after a salmon or a trout.
Biomimicry is the way to go, I think. I want to mention the boxfish study that Mercedes did - the computer model of the fish had a Cd of 0.06:
http://ecofriend.com/wp-content/uplo...ncept_car2.jpghttp://www.speedace.info/solar_cars/...fish_model.jpg |
Bub
bluefin tuna
For what I have for fish,the authors report the same thing,that the bluefin has the lowest drag form of all the pelagic fish.
The bummer is trying to locate plan views of the fish,as most of the water goes around their sides rather than below or over.These views would really show where the action is,and frustrates a complete analysis.:( |
http://ecomodder.com/forum/member-te...orsal-view.jpg http://ecomodder.com/forum/member-te...a-profiles.jpg Description from site: Quote:
A Comparison of the Bluefin Tunas, Genus Thunnus From New England, Australia and California1 |
Just a bit more:
http://ecomodder.com/forum/member-te...ness-ratio.jpg http://ecomodder.com/forum/member-te...ing-action.jpg And here's a quote from the site, studying different swimming actions in fish, think you'll like the bit about the Fineness Ratio: Quote:
images
Thanks alot!
These are the first I've seen after years of waiting. The Edison-2 folks will enjoy the reflexed camber in the aft-body. My chart showed a Length/Width ratio a little smaller but close to 4. This is the ratio of lowest drag for sections and struts.Fun coincidence!:D |
Some 'fishy' and other numbers
One of my books about sharks presented the following data:
These marine creatures are presented according to their body length,divided by there maximum body width as measured from above (plan-view) *Bluefin tuna--------------------------------------------------- 3.571:1 *Swordfish----------------------------------------------------- 4.166:1 *White shark (JAWS) ------------------------------------------- 3.846:1 *Cod ----------------------------------------------------------- 6.25:1 *Mackerel ------------------------------------------------------ 7.142:1 *Eel ------------------------------------------------------------ 20.0:1 *Blue whale -----------------------------------------------------4.76:1 *Bottle-nosed dolphin --------------------------------------------4.00:1 *Emperor penguin ------------------------------------------------3.846:1 *Harp seal ------------------------------------------------------ 4.166:1 -------------------------------------------------------------------------- According to Sighard Hoerner,a symmetrical wing section or strut would have a drag minimum at L/W= 4.00. You can see from the list that six of the listed swimmers are near this drag minimum. |
