BMW i3 "bricked" at the charger!
Dutch carmag AutoWeek is subjecting a BMW i3 with range extender to an endurance test.
The other day they found it dead at the charger. This could happen to other electric cars too. http://media.autoweek.nl/m/do6yyqlbfc15_800.jpg So here is the report of what happened, what caused it, how they resolved it, what they should have done and how to prevent it in the first place. Quote:
Had they done that they would have noticed it did not work and maybe go to another point or skip the charging. And of course, when it is bricked like this do not drag it on a tow vehicle but jump the 12V battery and switch on the ignition so the main battery takes over recharging the 12V battery... Last week a colleague of mine had a Renault Zoe as a courtesy car. Our company provides free charging points, but we could not get it to charge the Zoe. We left it with the cable in the charger all day, but it did not charge it. Glad we did not brick the Zoe. Turns out you do still need a special charge payment card to make it work (he brought that out the next day). The card will not be 'charged' - unlike the car ;) |
my juicebox "bricked" my leaf while trying to troubleshoot the juicebox. Left it thinking it had zero charge (and I was in a rush). I was able to plug in the panasonic for a few seconds and the leaf then remembered it had a charge. (j1772)
This isn't the definition of "bricked" that I know!
I thought if it were truly "bricked", it would be wrecked (meaning: major components needed to be replaced to make it functional again). Quote:
It needed a 12 volt jump, lesson should be learned. Brother had the same problem with his Prius. Dumb dealer left it sitting in the showroom with the doors open and dome light on until it killed the 12 v batt, then sold him the car after charging the batt which was destroyed by being totally discharged, to the point where it would not even light the dome lamp.
Bricked is when the lithium battery has been totally discharged down to 0 current potential. regards mech |
you can imagine that the meaning of "bricked" has devolved a bit. A lot of times a unit of somesort can be reflashed, or have just the right comm signals sent to it.
So "bricked" sort of depends on the skill level/tools availibility/knowledge avalibility/persistance of the user. It isn't necessarily permanent. Though for some item's like computers, it often isn't worth it to the company to bother resucissitating it. Looking at wikipedia, there are divisions known as "soft brick" and "hard brick" :/ Brick (electronics) - Wikipedia, the free encyclopedia where hard brick would require a jtag programmer (and appropriate hex files). One mans junk is another mans treasure. |
True all. It was not literally bricked, but they treated it as such.
Have to say they did not call it bricked, that's my translation. (though 'dead' does not sound less dramatic) I now added hyphens to "bricked" in the thread title. With all the attention to the main battery people tend to forget that it has a 12V battery, and that that can fail. If the car had an ICE they would have tried a jump start without even thinking. It even has an ICE - though not connected to the drive train! |
Same thing happens with the Gen1 Insight: even if the main battery is fully charged, the car won't run if there's not enough juice in the 12V battery. (Or if the 12V battery is bad, which happened to me once.)
Also shows the amazing advantages (NOT!) of electronic remotes & battery cable controls :-) |
yah my prius battery went south, had to jump the 12v under the hood so I could pop the trunk to get to the battery. There is usually a "way", but best to know it before you need it.
This can happen to any car. No ICE charges it's 12v battery when parked.
I planned ahead for this in my conversions, and have installed a low voltage cutoff for my 12 volt battery so that it will disconnect if it goes too low,and I have a manual reset button for the latching solenoid that disconnects it.
