boost gauge?
hey all,
i got a boost gauge for free….i was wondering if i could use it as a vacuum gauge? |
That depends, does it also measure vacuum?
I was under the impression a boost gauge was just a vacuum gauge.
My boost gauge has both on the same dial. The left 1/3 of the face is vacuum the right 2/3rds is boost. It will function as one or the other but not both at the same time.
It is a Equus brand |
its just a boost gauge not both, but a boost gauge hooks up to the waste gate? on the turbo? mine will be hooked up to an engine vacuum source i wonder if the gauge will read with opposite pressure? or will it be the same:confused:
It won't work, since it is not capable of reading vacuum which is lower than atmospheric pressure, versus postive pressure which is boost.
regards Mech |
The boost gauge reads the turbo's positive psi pressure which moves the needle right.
A vacuum source on it would move the needle left / negative pressure. Sounds like yours was not marked to go backwards - but it might , you never know until you try , despite being no scale to measure it with you could watch for peak vacuum or what ever. try it on a vacuum source or draw a breath threw it and see if the needle moves backwards. |
We need a picture!
I have a boost gauge (unsure of brand) on a Volvo 940 Turbo and you can definitely use it as a vacuum gauge.I stay out of boost 90% of the time I drive it and use it as a vacuum gauge,and it does a great job!The needle can show you negative pressure(vacuum) as well as positive (boost).
