EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   bought a 2004 echo base manual last week (https://ecomodder.com/forum/showthread.php/bought-2004-echo-base-manual-last-week-32857.html)
echomiser 10-01-2015 05:28 AM
Just found this site, my target is 50mpg. So far on my first tank of fuel waiting to see what mpg numbers return when I fill it. I Average 2000km per month. For now I'm gliding down hills and keeping revs as low as possible. Then onto the grille blocks and underbody air smoothing with a warm air intake.
user removed 10-01-2015 06:34 AM
Tire pressures at sidewall max.
Welcome
regards
mech
Fat Charlie 10-01-2015 08:19 AM
Nice! Welcome aboard.
Daox 10-01-2015 08:46 AM
Welcome to the site and congrats on a good car. Keep us up to date and please make a garage entry ('garage' link up top) and fuel log for the vehicle.
echomiser 10-01-2015 11:38 AM
Will do
user removed 10-01-2015 05:38 PM
Details: Echo-Troll - 2005 Toyota Echo Fuel Economy - EcoModder.com
Number 3 on the gas cars (non hybrid list on this site) but I would bet he is very serious and his average speeds are fairly low.
regards
mech
echomiser 10-01-2015 07:28 PM
My average speed only increases when gravity allows. I'm stuck at near 50-50 city hwy with bad city traffic. So far the fuel gauge says I've burned 1/3 (guessing 15-17L) of the tank @330km. I'm impressed. My Lexus (sold today) could never get near this. I'm used to gas guzzling cars. The echo is a welcome relief and challenge
user removed 10-01-2015 07:43 PM
Blow the tires up, short shift it, and coast yer arse off. Learn the light timing on your usual routes. 50 should be fairly easy at those speeds, but you might need a block heater for winter.
regards
mech
Fat Charlie 10-01-2015 08:38 PM
We forgot the first thing: get an SG or a UG immediately!
California98Civic 10-02-2015 12:23 AM
Welcome. Your easiest, low hanging fruit still is the tire pressure boost Old Mech noted and the gauge Fat Charlie just recommended. Tire pressure is free. A UG (UltraGauge) is $70 US. But the UG will pay for itself in a few tanks, and it can help you detect engine trouble, and allows you to read engine trouble codes that explain what set off the check engine liht when it happens. I'd do those before a bellypan.
Good luck.
James
Donahue 10-02-2015 01:51 AM
Welcome!
echomiser 10-03-2015 08:02 PM
In not sure I have the patience to get a firm baseline, I want the results now. Still a bit over half a tank 430km. After this tank ill bump the tires, next tank grille and so on..
The gauge is a great idea I've got a nice code scanner that reads out engine information while running. I'm going to do my best to beat down my mpg's before I look to computer intervention. That said, I will end up buying one definitely.
