EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   brake monitoring (usage) (https://ecomodder.com/forum/showthread.php/brake-monitoring-usage-25556.html)
bestclimb 04-14-2013 10:52 PM
We all know that misusing brakes can reduce efficiency. So Brake usage awareness could be nice. How about a simple system that counts the number of brake applications via an electrical signal from the brake lights.
Or
A pressure sender on a brake line, hooked to an Arduino. counts time at various pressures. Some math based on the weight of the vehicle, time and pressure. You could figure the amount of energy/number of gallons dissipated by brake usage.
jeff88 04-15-2013 02:09 AM
I like the idea, but don't know how it could be done.
It would be cool if you could have a little display that shows like a graph or something to show you how much pressure is being applied and/or a hard drive or storage device to save it to your computer later. It could help you determine if you are applying too much pressure for a short period or if you are braking lighter over longer distances.
Just a thought.
MetroMPG 04-15-2013 09:30 AM
Do you have a smart phone?
I'd be surprised if there wasn't already an accelerometer-based app that would do something like this for you.
Piwoslaw 04-15-2013 10:40 AM
... Add in periodic replacements of rusted brake rotors...;)
bestclimb 04-15-2013 12:16 PM
my mechanic already says "if it were any of my other customer's cars I would suggest replacing the pads. But yours are good for another year or two.
MetroMPG 04-15-2013 01:12 PM
Ha! Good story. You know you're an ecomodder when...
user removed 04-15-2013 02:02 PM
I got 65k on the original pads on my 94 VX when I sold it and there was at least 50% left. Usually when I need brakes is when I get nailed by a poorly timed traffic light. Not sure how knowing how much I use brakes would do any good. I might as well go the the city councils and complain about their atrocious light timing.
regards
Mech
