04-14-2013, 10:52 PM
Smeghead
brake monitoring (usage)
We all know that misusing brakes can reduce efficiency. So Brake usage awareness could be nice. How about a simple system that counts the number of brake applications via an electrical signal from the brake lights.
Or
A pressure sender on a brake line, hooked to an Arduino. counts time at various pressures. Some math based on the weight of the vehicle, time and pressure. You could figure the amount of energy/number of gallons dissipated by brake usage.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
04-15-2013, 02:09 AM
Lots of Questions
I like the idea, but don't know how it could be done.
It would be cool if you could have a little display that shows like a graph or something to show you how much pressure is being applied and/or a hard drive or storage device to save it to your computer later. It could help you determine if you are applying too much pressure for a short period or if you are braking lighter over longer distances.
Just a thought.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
04-15-2013, 09:30 AM
Do you have a smart phone?
I'd be surprised if there wasn't already an accelerometer-based app that would do something like this for you.
04-15-2013, 10:40 AM
aero guerrilla
... Add in periodic replacements of rusted brake rotors...
04-15-2013, 12:16 PM
Smeghead
my mechanic already says "if it were any of my other customer's cars I would suggest replacing the pads. But yours are good for another year or two.
04-15-2013, 01:12 PM
Ha! Good story. You know you're an ecomodder when...
04-15-2013, 02:02 PM
I got 65k on the original pads on my 94 VX when I sold it and there was at least 50% left. Usually when I need brakes is when I get nailed by a poorly timed traffic light. Not sure how knowing how much I use brakes would do any good. I might as well go the the city councils and complain about their atrocious light timing.
regards
Mech
