EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   The BSFC chart thread (post 'em if you got 'em) (https://ecomodder.com/forum/showthread.php/bsfc-chart-thread-post-em-if-you-got-1466.html)
MetroMPG 03-19-2008 12:00 AM
Had a suggestion to post BSFC charts for various vehicles in one place. If you've got one, post it in this thread. I'll add an index in this first post if it gets long.
Geo/Suzuki 1.0L SI engine
Thanks to tasdrouille who posted a link to a fuzzy - and the only - bsfc chart I've yet seen for the Suzuki/Geo 1.0L, non-XFi engine (judging by power rating):
The original, fuzzy image:
Cleaned up image. Note: I "best guessed" a few digits:
http://ecomodder.com/imgs/geo-1L-bsf...nstruction.gif
Note that peak torque for this engine is listed as:
Torque(lb/ft) @ RPM: 58 @ 3,300 (Non-XFi Models, XFi not listed - source)
And 58 lb/ft = 78.6 Nm (calculator)
Straight-3 03-19-2008 02:28 AM
Ok.
What I'm getting: Driving at WOT from about 2600 to 3600 rpm will yeild the minimum fuel used for power produced.
What I'm wondern: Why is there so much data on the graph? Like islands instead of just a line, theres seems to be 8-10 points plotted for every rpm from 1100 to 5000.
Straight-3 03-19-2008 02:51 AM
Wait a sec... the aliens were just communicating with my brain... Each line is just fuel consumption for a given torque and rpm, throttle position is not represented on this graph. I think.
cfg83 03-19-2008 04:20 AM
1 Attachment(s)
Hello -
Here's one for my Saturn 1.9 liter DOHC engine :
http://forum.ecomodder.com/attachmen...9&d=1205914740
Attachment 469
I got it from here :
Fuzzy Pareto Frontiers in Multidisciplinary System Architecture Analysis
http://web.mit.edu/deweck/www/PDF_ar...-2004-4553.pdf
CarloSW2
tasdrouille 03-19-2008 08:17 AM
Here's one illustrating NA vs Turbocharged for a given engine. It clearly shows how a turbocharger can lead to better FE as you can downsize the engine and get the same power output, but you extend the bsfc sweet spot to lower loads vs the bigger engine.
http://www.tc.gc.ca/programs/environ...e/Final_30.gif
MetroMPG 03-19-2008 08:43 AM
cfg, do you know what the line is at the top of your chart with the points marked on it? The original Geo engine chart appears to have a similar line.
jwxr7 03-19-2008 09:08 AM
Here is a chart for a 2001 GM vortech 4.3l v-6. It shows both, the truck and marine applications.
Brake Specific Fuel Consumption
The engine brake specific fuel consumption (bsfc) shall be as follows:
1. The engines nominal brake specific fuel consumption point on a W.O.T. curve is shown in
table 6.3 -I.
2. The engine nominal specific fuel consumption shown in table 7.3 -I are for an operating range
between peak torque and maximum power at full load.
3. The engines best part throttle bsfc (on a fuel map) is shown in table 7.3 -I.
Table 6.3 L35 V6 4.3L Engine BSFC
rpm truck marine units
800 0.529 0.495 lb./BHP-Hr
1200 0.521 0.478 lb./BHP-Hr
1600 0.484 0.481 lb./BHP-Hr
2000 0.470 0.471 lb./BHP-Hr
2400 0.471 0.466 lb./BHP-Hr
2800 0.469 0.472 lb./BHP-Hr
3200 0.478 0.458 lb./BHP-Hr
3600 0.483 0.452 lb./BHP-Hr
4000 0.500 0.460 lb./BHP-Hr
4400 0.525 0.479 lb./BHP-Hr
4800 0.532 0.506 lb./BHP-Hr
5200 0.556 0.550 lb./BHP-Hr
cfg83 03-19-2008 06:10 PM
MetroMPG -
Nope, I don't speak BSFC. It's just a topo-map to me. I'm sure someone else will pipe up and say what it is.
CarloSW2
tasdrouille 03-19-2008 06:50 PM
I always thought it was simply the torque curve at WOT through the whole range. I could be mistaken though.
boxchain 03-20-2008 12:37 AM
I agree that those look like torque curves...
So this is a load vs speed graph that maps fuel/power gradients :D ...the way I'm reading them is that the sweet spot for acceleration is about 1/2 to 2/3 throttle (y-axis...load really) at 1500-3500 rpm, depending on what your torque curve looks like.
MetroMPG 03-20-2008 07:53 AM
If that line does show torque at WOT, that may make it incredibly useful: could you not essentially use it to extrapolate what throttle/pedal position to use to get the engine closest to the sweet spot at a given RPM?
EG. in the Saturn chart, 7/9 throttle @ 2000 RPM looks like it would put you squarely in the 250 g/kWh island.
Of course it doesn't work quite that simply, because the engine doesn't "idle" at 2000 RPM ("0/9ths"), so you'd likely have to factor in the amount of pedal required to get there with no load on the engine.
tputus 03-20-2008 08:35 AM
Why the reduction in efficiency at higher loads?
Retarded timing? Or does EGR matter that much efficiency wise?
@ MetroMPG
Most gas cars have a very nonlinear accelerator travel vs. torque output response. How a bout measuring acceleration vs pedal position at lower speeds with the ScanGauge? Maybe up a hill?
MetroMPG 03-20-2008 08:40 AM
Re: efficiency reduction @ higher RPM - I'd guess that increasing internal friction also plays a role. Power required to overcome friction is an exponential relationship. Just a thought.
Good point on tps vs. torque.
Daox 03-20-2008 09:47 AM
Timing changes and pushing the engine into open loop causing fuel enrichment I would think is what causes the drop off at the extremely high loads.
Duffman 03-20-2008 07:43 PM
Yes, min BSFC should be at the same RPM as peak torque as is in this case.
I agree.
AXMonster 03-22-2008 01:21 PM
What you need to do with the plots now is calculate the engine torque at various engine speeds in all gears, then plot the results over the BSFC plot to give the road curves Vs BSFC.
Then you have all you need to drive at theose BSFC points you choose :)
If you don't have any efficiencies then calculating the engine torques for road speeds may be a little difficult, but allowing 23% for drivetrain losses is a typical figure.
A more reliable method of getting the drive train losses is to stick the car on a roalling road and do a motored run in neutral to actually measure the power it takes to achieve the road speeds.
elhigh 03-24-2008 01:04 PM
I'd love to see one of these for the Toyota 22r - then I'd know for sure whether regearing my rearend is a good idea. Right now, it's just a feeling that the engine could be turning a lot slower and get the job done.
fabrio. 03-24-2008 02:21 PM
I am sercing that one of the tigra, engine X14XE, but I, do not succeed to find it.
you, can help me?
s2man 03-25-2008 03:06 PM
That's what I was trying to say in the shift timing thread. 7/9 = 77% of max torque (or load). Examining a bunch BSFC maps, and measuring the extents and center of the peak efficiency island, I found the average center point to be 72% of max load. Hence the question; Can we believe the LOD output on the scangauge as a good indication of engine load?
fabrio. 03-25-2008 05:25 PM
sorry, it is very difficult for me to understand that your has write and in the same manner, it is very difficult for me write to you that one I think...in Italian no problem, but an English I can only try :(
For an correctly reading of BSFC, the map it must be without the torque value, but with the % of PME max(pressure, average real).
The map is created put the engine in the braked dyno.
the BSFC it is a consguence of vary factors: engine respiation, friction and AFR.
The engine respiration it is defined by cams phases, valves diameters, intake and exhaust tubes lengs and diameters, resonace and pulsation phenomena.
When the respiration is at the optimum, the respiration friction losses it is at the minimum, obviously at open full throttle.
The engine friction loss increase with the engine revolution, and the AFR it is an other trouble factor.
When we interpolate all factor then obtain the BSFC map.
For to go the engine in the optimal fuel economy (in this case by 250 gHP/H), it is necessry the needed load.
In normal operation, in flat road, in the last gear and without acceleration, it is impossible go to optimal area of BSFC.
Only way, it is to decrease the engine torque available the same rpm and car load throoughout AFR modification.
This, does not have effect on the friction loss and on the volumetric efficient, but only on the PME
So, we can free-moving the engine load (point in the BSFC map) with the same engine torque output
I am understandable?
tasdrouille 03-25-2008 08:06 PM
I just installed an air dam on my TDI today and as I was coming back from work I was looking at my boost gauge when it hit me.
If a SG can accurately output engine loads, then all other things being equal, this would be an incredibly easy way to test aero mods. You get a baseline load at 75 mph, install your mod and look how the load differs at 75 mph again.
s2man 03-26-2008 11:19 PM
I think the torque can be as useful as the engine pressure (BMEP). Yes, there are losses due to friction and respiration. But I think the torque Y axis still gives us a good measurement of force, since higher pressure in the cylinder will result in higher torque. BSFC maps seem to use torque and pressure interchangeably.
For to go the engine in the optimal fuel economy (in this case by 250 gHP/H), it is necessary the needed load. In normal operation, in flat road, in the last gear and without acceleration, it is impossible go to optimal area of BSFC.
Yes, we are talking about accelerating, not normal operation. But at normal operation, we should also be able to change the engine load slightly through gearing. Higher gears will make the engine turn slower, needing more open throttle and higher load to put out the same power.
This thread has me thinking about what I should do next. I have parts for two tests: a full rear-body lip for air-flow separation testing, and an adjustable throttle limiter for acceleration tests at different throttle positions. I was planning to do the aero test first, but now the throttle position has my mind occupied. I watched the LOD out put on the ScanGauge today, and I can not believe I'm reaching such high loads at low throttle positions.
MetroMPG 03-28-2008 03:07 PM
The difficulty with this is LOD is an instantaneous gauge on the SG. It's difficult to get an accurate picture, since it fluctuates readily.
I wish those gauges were also "averaging" like the "trip" MPG function. Then you could reset the gauge as you pass a marker and record the average reading when you pass a second marker. Even with a short duration, it would be much more reliable data than trying to read instant figures.
tasdrouille 03-28-2008 03:15 PM
I had the chance to play a little more with the SG today and that's what I realised.
Daox 03-28-2008 04:24 PM
I really just wish it did datalogging. :)
cfg83 03-28-2008 04:41 PM
MetroMPG -
Maybe you already know this, but you can change the duration of the instant gauge :
ScanGaugeII With XGauge Manual - Page 25
http://www.scangauge.com/support/pdfs/SGMan5_0.pdf
MORE -> MORE -> RATE
This sequence will allow you to change the gauge update rate.
RATE FAST>
<NORMAL SLOW>
The update rate defaults to NORMAL. In some cases, a faster update rate
can be used. If this causes some updates to be skipped or irregular
operation, FAST should not be used. In some cases even NORMAL can
be too fast and lead to poor operation. In these cases, SLOW should be
used. PWM and all the CAN modes can usually use FAST rate. VPW,
ISO and KWP modes may have a problem with a rate higher than
NORMAL.
However, I don't know if this is doing accumulatoon, :( .
CarloSW2
cfg83 03-28-2008 04:47 PM
Daox -
Supposedly that feature is "in the pipe", but it hasn't happened (yet).
CarloSW2
MetroMPG 03-28-2008 08:46 PM
Unfortunately, no, it's just the refresh rate of the instant gauges (and, I suppose, how often the average is updated on the trip/tank stats).
The MPGuino will likely have these features... eventually :)
RH77 04-12-2008 12:12 AM
Little on Hondas
I've searched for a while and haven't found anything close to a BSFC chart for a Honda non-VTEC engine. A recent Autospeed article had a good one for the Insight, but it's a radically different engine and VTEC-equipped.
If anyone comes across one, I would appreciate it. Thanks :thumbup:
RH77
fabrio. 04-12-2008 03:20 PM
same problem with my opel tigra engine, the X14XE
Could you tell me how I can find the bsfc of my car?
thanks
Daox 04-17-2008 11:49 AM
1 Attachment(s)
Here is the BSFC chart for Toyota's original 1ZZ-FE when they developed it back in 1998. Interesting how the lowest BSFC is so high in the rpm band. It would be really great to get updated info on the newer versions of the 1ZZ. I know there were some fairly descent changes to it over the years.
1ZZ-FE:
4 Cylinder
1.8L
16 Valve
http://ecomodder.com/forum/attachmen...1&d=1208447138
MetroMPG 04-17-2008 11:57 AM
Interesting - what's the displacement?
EDIT: and valves/cyl?
Daox 04-17-2008 11:59 AM
Edited the post to include that info.
This post could probably be stickied too.
MetroMPG 04-17-2008 12:01 PM
I'm not really sure. Persistent Google searches?
I wasn't able to find one for my engine when I first started looking. And the one Tasdrouille found for it wouldn't have come up in a Google search anyway - the relevant information was within the image itself, not the text.
Daox 04-17-2008 12:05 PM
I'm wondering, has anyone called up a dealer to see if they have this information avaliable? Obviously legacy info may be a problem, but at least current production maybe?
holypaulie 04-23-2008 09:44 PM
Where can I find BSFC map for civic 03 ?
tasdrouille 04-27-2008 03:42 PM
Here's for the ALH TDI engine 1999.5-2003
http://pics.tdiclub.com/members/tdim...engine_map.jpg
MetroMPG 04-27-2008 03:46 PM
Interesting - so far I think that one wins for peak efficiency at lowest RPM.
TEiN 07-09-2008 02:29 PM
So what can we glean from this map? Does it indicate that peak efficiency for acceleration would be at nearly full throttle (up to and including full throttle?) from ~1500 rpms to ~2200 rpm?
Could we say >75% TPS from 1500-2200 rpms would be best for the pulse portion of P&G?
dcb 07-09-2008 02:53 PM
You could say that, my guess is that since it looks like only half an "oval" that just floored between 1500-2200 RPM is more optimal. That little 197 dot is pretty close to the torque curve.
