Old 03-20-2010, 09:42 AM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Driving light placement?
Will driving lights on top of a bumper create a significant amount of drag? I'd like to put a pair of relatively small lights (Hella FF50) on a 1991 Civic Wagon, but I'm concerned about them affecting airflow over the hood. I could mount them in lower grill, but they'd be less effective down there.
Old 03-20-2010, 02:09 PM   #2 (permalink)
...beats walking...
...in the grill is less problematic; it's already an eddy location.
...with "fog" (yellow) lamps, you want them as close to the ground as possible, but up enough to keep them out of harms' way.
...with "driving" (white) lamps, you actually want them as high off the ground as possible, so as to illuminate further down the road, assuming they're powerful enough to reach that far (look at where they're located on endurance Rally race cars).
...otherwise, they're basically just "illuminated" bling.
Old 03-22-2010, 05:56 PM   #3 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
Mount them behind the grill! then get a hole saw and modify the grill to clear em.
I had some 130W air craft landing lights behind the grill on my Ram (Par36) wired in as my highs. AWESOME and the grill wasn't even clearanced for em
- Greg
Old 03-22-2010, 08:49 PM   #4 (permalink)
...beats walking...
...I, too, replaced the original "12V Fog Lamps" on my AAR 'Cuda with aircraft landing lamps...and had to install a separate relay to handle their higher current loads.
...how many people are aware that the decal lettering "LOAD AMPS" is easily changed to "ROAD LAMPS" by simple cut-n-pasting!?!?
Old 03-23-2010, 08:37 AM   #5 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I think the grill is just too close to the ground for driving lights.
Maybe I'll try taping some faux lights to the car and see if I can measure any increase in drag.
Old 03-23-2010, 10:57 AM   #6 (permalink)
If they're that small I bet it doesn't matter.
Look at the headlights on the Pagani Zonda
Old 05-02-2010, 02:48 AM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
They're on. I have no idea what they're doing aerodynamically, but they're bright!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 05-02-2010, 03:56 AM   #8 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I have mine in the lower grille. They light up where the headlights don't, and work perfectly for me, especially pointing some light around sharp corners.
In Reason we Trust
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 06:42 PM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
4th brake light and Rear fog light. Sean T. Off-Topic Tech 10 11-27-2008 12:29 AM
