EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Building a vacuum accumulator, size question...? (https://ecomodder.com/forum/showthread.php/building-vacuum-accumulator-size-question-17159.html)
caferacer51 05-03-2011 04:12 AM
Hi guys, I want to build a small vacuum accumulator tank/reservoir of my 944cc V-twin Ducati.
A bit of google bashing has given me an idea of what to build, but I don't know what capacity?
Is there a rule/ratio...?
JethroBodine 05-06-2011 07:13 PM
If it were me, I'd make it about the size of a beer can and wrap a vinyl sticker around it of your favorite beverage. My '73 Beetle (2 speed auto) used vaccuum to shift from low to not-so-low and had a chamber of about a quart if I remember correctly.
dcb 05-06-2011 08:39 PM
If you are just trying to smooth out the readings on a vacuum gauge, you might just try a restriction by the engine side of the hose so that the hose itself acts as an "accumulator". Don't put something together that the engine can injest. Maybe a bit of dowel rod shoved in the hose that you drill out progressively till you are happy with the readings.
