Old 05-03-2011, 05:12 AM   #1 (permalink)
Building a vacuum accumulator, size question...?
Hi guys, I want to build a small vacuum accumulator tank/reservoir of my 944cc V-twin Ducati.
A bit of google bashing has given me an idea of what to build, but I don't know what capacity?
Is there a rule/ratio...?
Old 05-06-2011, 08:13 PM   #2 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
If it were me, I'd make it about the size of a beer can and wrap a vinyl sticker around it of your favorite beverage. My '73 Beetle (2 speed auto) used vaccuum to shift from low to not-so-low and had a chamber of about a quart if I remember correctly.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 05-06-2011, 09:39 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
If you are just trying to smooth out the readings on a vacuum gauge, you might just try a restriction by the engine side of the hose so that the hose itself acts as an "accumulator". Don't put something together that the engine can injest. Maybe a bit of dowel rod shoved in the hose that you drill out progressively till you are happy with the readings.
