EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Bumped my FE (https://ecomodder.com/forum/showthread.php/bumped-my-fe-26773.html)
Jasen 08-24-2013 01:40 AM
Bumped my FE
My first tank trying to improve my FE got me a 1.2 mpg bump with no mods.
I know not great, but I'm learning the shift points of the auto trans, not going over the posted speed limit, trying to maintain a more content throttle position.
Just need the weather to cool down so I can roll the windows up.
cbaber 08-24-2013 01:46 AM
From your last tank to this tank is a 1.2 MPG increase. It doesn't sound like much, but that's actually about 8% better! Your driving will continue to improve. What pressure are you running in the tires? A free/easy modification is to pump them up to sidewall max (or more if you dare).
Jasen 08-24-2013 02:03 AM
Your right, I read the last tank as 14.4, it's 14.04
I keep the tires at the max 35psi. There only passenger tires and I haul a 1,500 lb load everyday. I'm not comfortable over inflating them in this situation for safety's sake.
I plan on getting some LT 3 ply sidewall tires in October, those I'll run up to 50-55 psi, they also have a bit better FE rating then my current tires, plus will offer a more stable and safe ride.
MetroMPG 08-26-2013 12:56 PM
cbaber is right: don't be discouraged by a 1.2 mpg difference! It's a significant amount of fuel & money saved when you're talking about something as thirsty as your van.
You would save $392 a year (20k mi., $3.61 gas) by going from 14.04 to 15.2 MPG (1.16 mpg difference).
fueleconomy.gov mpg/cost calculator: Save Money
If a Geo Metro driver made a 1.16 mpg improvement from a 50 mpg starting point, it would only save $33 a year for the same distance/gas cost.
(There's the problem with talking in "MPG" in a nutshell. But that's another topic.)
Keep going! :D
jedi_sol 08-26-2013 05:42 PM
Dont fret...its all the little things that add up in the end. A lot of the mods we do here only net us 1-3 mpg at a time. However, if you "stack them...3mpg, 2mpg, 3mpg...1mpg...1 mpg"...before you know it, you have a 10mpg increase over EPA.
UltArc 08-26-2013 06:34 PM
Of course everyone else makes very valid points, going for the long haul will make a difference. I think about my antenna delete, and I would probably need serious equipment to calculate the difference, but over the years of owning it, I am sure it will pay the ~$3.00 it took to make it.
Every little bit adds up!
elhigh 08-26-2013 07:23 PM
Better than you think
Don't feel bad, man - you're exceeding the EPA estimate with 1500 lbs aboard all the time? You're doing well.
Jasen 08-26-2013 08:28 PM
thanx gang.
I'm still learning to drive my van, I've only had it for 9 years:D
Driving my shift points is starting to feel natural, don't hardly watch the speedo now, can just feel it's time make it up shift.
pgfpro 08-28-2013 11:50 PM
Originally Posted by Jasen (Post 387356)
thanx gang.
Keep up the good work!!!
As others have already said every little bit makes a difference.:thumbup:
owly 09-05-2013 12:31 PM
Before you know it, you'll be having to stop and drain gas out of your tank ever 100 miles or so ;-)............
