EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   bumper help (https://ecomodder.com/forum/showthread.php/bumper-help-33844.html)
sully06 05-19-2016 07:13 PM
bumper help
I'm replacing my damaged bumper on my 99 Camry and I'm debating on going with an aftermarket one as they are typically taller and will be closer to the grouf as opposed to the OEM height. Some of the ones I'm looking at have more open area tho. Any thoughts/suggestions would be much appreciated.
ChazInMT 05-19-2016 07:49 PM
Anything you can do to make your bumper as vertical as possible and push as much air as possible around the sides, as opposed to over the top or under the car will help you out.
I like this if you block out the huge hole in the front as much as possible making the cooling hole as low and close to the center as possible.
http://www.bodykits.com/images/T144987736.jpg
The only real air inlet on this car is the one below "Camry" and half of it is taped shut when it's go time.
http://i.imgur.com/ipJuoDK.png
sully06 05-19-2016 10:22 PM
That's actually the one I was thinking about going with. On my oem bumper I typically block out the entire bottom and just leave the top open for cooling.
freebeard 05-19-2016 10:58 PM
http://ecomodder.com/forum/member-fr...hlf3lbyhtg.jpg
Zip ties are also popular.
freebeard 05-20-2016 04:17 PM
http://www.motifake.com/image/demoti...1364534460.jpg
http://www.motifake.com/necessary-tools-shelby-cobra-duct-tape-zoomer-demotivational-posters-164710.html
aerohead 05-20-2016 05:40 PM
bumper
A single,size-optimized and ducted opening at the forward stagnation point is preferred.
http://i1271.photobucket.com/albums/...itled24_10.jpg
Ground clearance is a big issue.Here are the recommendations which will allow the car to stay in one piece
http://i1271.photobucket.com/albums/...titled4_19.jpg
freebeard 05-21-2016 02:12 AM
The 'back 40 is fenced and cross-fenced. Optimized for lefts?
aerohead is too modest to toot his own horn:
https://strollingamok.files.wordpres...pg?w=807&h=539
https://strollingamok.wordpress.com/2014/09/30/taking-cheapskate-seriously/
Bonus points for it being round. That's a nice write-up.
The sense of accomplishment must be strong, I imagine, but is there such a thing as tedious excitement?
sully06 05-24-2016 12:38 PM
The factory ride height is quite high on that body style Camry. I'm also lowering the car 2 inches so with that and the aftermarket bumper I should be close go the ground but not too close
freebeard 05-24-2016 01:02 PM
http://ecx.images-amazon.com/images/...nL._SY300_.jpg
http://amazon.com
Let it grind. :thumbup:
